Hi all,
I'm thinking of swapping my standard dealer fitted Toyota heavy duty hitch receiver for a Hayman Reese heavy duty hitch receiver after reading about the toyota hitch failing when being used with a HR weight distributon hitch.
With the dearler fitted tow hitch a section of the rear bumber has been cut out to accomodate it. It appears that with the hayman reese hitch it doesn't require as much of the rear bumber being removed.
What have others done in this situation? Does it look ok with a hole in the bumber above the hitch? Any suggestions or comments???
