Factory Jack Failure
  • Factory Jack Failure
    The day before i was due to get new tyres (after 89800km off the Grandtreks) i got a puncture. When changing the wheel on almost flat ground on concrete in the hills, with the flat off and whilst reaching for the spare next to the car i heard a bit of a bang and watched the jack collapse and the car fall onto the shock strut and the rear bumper.
    On closer inspection i saw the jack base had opened up and the gear sheared in half and spilled onto the ground - not to mention a heap of ball bearings.
    This was the first time the jack had been used. Has anyone else had similar problems with the factory jack?
    Thankfully i didn't have any body parts under the car when it happened and a local came back with a trolley jack and a cold beer which was well needed.
    2007 GXL D4D, WHITE, SOVEREIGN BULL BAR, TOYOTA CROSS BARS, RHINO ALLOY TRAY, TOW BAR, DUAL BATTERIES, TINT, ELECTRONIC RUST PROTECTION, REAR CARGO MAT, REVERSING SENSORS & CAMERA, LIGHTFORCE 170S, GME TX3340, SCAN GUAGE II, SAFARI SNORKEL, BFG AT, FALSE FLOOR, ENGEL 4OL, PP REAR TABLE.
    Re: Factory Jack Failure
    Bugger, I've never used the factory jack as I bought a 3T hydraulic jack to replace the factory jack.
      Lucky Lucky
      I've always put the spare and then the tyre I've just taken off under the chassis as a safety measure in case the jack slipped but for it to just colapse...
      mind you we had to change a tyre on a new toyota bus the other day and the jack wouldn't even fit under the jacking point to lift the vehicle. and this was on level ground
      A tourist is a fellow who drives thousands of miles so he can be photographed standing in front of his car
      [size=7][b]Go Hard or Go Home...[/b][/size]
      [i]...and take your bloody Nissan with you...[/i]
        Many of us now carry a hydraulic bottle jack in addition to the OE jack.
        Have a look here :
        viewtopic.php?f=4&t=6421
        I wouldn't use the factory jack as first choice now I have the bottle.
        Belly, given your experience, and assuming your jack is not a one off fault, I reckon this is actually a major safety issue with these jacks.
        Should be reported perhaps ?
        Cheers, Wayne
          I use the hydraulic jack from my old Defender/Dico (forget which) as it's a far better item of equipment. It's got a bent bar across the top as well which helps with location instead of that silly little thing the original for the Prado has.
          It fits OK into the space provided as well with a little cutting of the holder in there.
          Definitely a cause for complaint but I don't suppose they want anything else being seen to be unsafe about their vehicles!
          Alan
            Thanks for your comments guys! I have taken your advice on board. I now have a new bottle jack and finally Toyota have come to the party and will replace the broken jack. However no confirmation on any recalls...
