Squeaky Factory Bullbar
  • Squeaky Factory Bullbar
    I have toyota's sovereign bullbar and for some reason it tends to squeak from the LHS. Can be heard whilst driving over bumps or shutting passanger side doors. If i spray a bit of wd40 around, it stops for a week or two. It might be that wheel arch black plastic thing but it's starting to drive me nuts and toyota can't work it out neither. Anyone else has this?
    Also a little rattle around the dash - gray plastic surrouning the 2nd start button. Has anyone had this before? I tried pushing it all the way and it stops, so any ideas of how to do it permanantly so i don't have to have someone's finger holding/pushing on it?
    Re: Squeaky Factory Bullbar
    Hi Mate and take the two black plastic covers off the front,(only two philips head screws) and check the two bolts that are there,I did trip to Fraser,and after on the black top heading back to vic,noticed the noise comming from front Bullbar.
    found that the Bolts do come loose,anyway check them and hope this helps you out..
    we are all here for a good time,not a long time,so enjoy it while you can..
