search help needed
  • search help needed
    Sorry fellas, but ive been searching for someones step by step suspension installation, ive seen it here before but cant find it, ive done a search in modifacations,suspension,etc but cant find it , i think it was a bilstein install does this ring abell for any one :| :|
    DIY 120 Series Suspension Install
    You will find most of the standard type suspension setups the same in terms of what needs to be done. Difference if you are putting in reservoir shocks. Have a look through the 120 Suspension sectionand also the built threads.
    Here are some details on an Old Man Emu install:
    http://pradopoint.com/viewtopic.php?...1686220c30817b
    You should also change the the thread title since it's a pretty ordinary
    [COLOR=#000080]Nick[/COLOR]
      Re: search help needed
      Thanks Shaffer, there the sites i was looking for, i will be putting a 50mm Ultimate lift in mine later this week, will post some measurements in measurements 2 when i get the job done cheers
