Techstream om 2009 120 d4d
  • Techstream om 2009 120 d4d
    Hello All,
    Looking after some techstream advice.
    I have installed version 13.00.22 and cant find prado or 1kdftv in the selection menu.
    I have selected land cruiser and tried hilux/4 runner also. not a lot of info available like injector values.
    what version you guys are using?
    Thanks in advance
    HI mate
    Im running a similar version of tech stream.
    Mine doesnt have prado either
    I use landcruiser and 2uz
    still brings up the 1kd info like injector values etc
    11/06 kdj120 gx wide body auto
      Thank you red hilux.
      Its working now.
        I am facing the same issue. I have the 13.00.22 version and cant find prado or 1kdftv in the selection menu.
        Unfortunatly I want to program a new key and 2UZ isnt recognizing the keys...
        Can someone share a version that has 1kdftv as an option?
          Fixed it by changing some parameters in BIOS configuration for coding (from "compatible" to "ANSI"
