Expected life span of starter motor?
  • Expected life span of starter motor?
    I replaced it in Oct-2019 and it failed this week which at just under 2 years, seems a bit on the short side. I had basically done zero proper off-roading until the last couple of weekends. Even then, no serious river crossings just a few deep puddles. Is this just the "cost of doing business"?
    Genuine Denso? Or aftermarket? Rivers and alternators & starters aren't friends on prados.
      They the solenoid on the starter does tend to corrode, if you go through some water crossings usually for me was within a few months of a water crossing, disconnect the batterie/s, and remove starter, clean internal solenoid contacts ( remove corrosion) and she'll be right for ages ( ive had to do this 3 times )
      I've had the car 5 years and its usually needed to be done within 3 months of water crossings.( 0.o)
      Or if in a hurry you can always try giving it a gentle love tap with a mini sledge type hammer, or rock if you are desperate!
