1kzte rattle noise
  • 1kzte rattle noise
    So I've had this subtle metallic rattling noise coming from the drivers side area. I can't pin point exactly where it is. Doesn't make the noise at idle, only makes the noise after about 2500rpm and goes away if I put into neutral, apply more acceleration or when the rev range goes down. Can especially hear it in 2nd gear happens in all gears though.
    I've searched far and wide for any loose bolts leaks, anything that stands out. I've replaced all the gaskets from the dump pipe back towards the rear of the car.
    Somebody please help
    You’ve checked heat shields, bash plate etc?
    Manual or auto?
      Yeah checked heat shields and bash plates. Manual
      pendik escort
      sex vidio
