Traction control/abs kicking in mid corner at low speed
  • Traction control/abs kicking in mid corner at low speed
    Hi guys, I have a 2004 120 D4D . I bought it and drove it home a few months ago and after fixing it up I have this dilemma. Traction control is kicking in at speeds as low as 30mph mid corner which is not fun. I have fitted Pedders uprated standard height springs with Bilstein shocks. I can't get my head around why it is doing what it is doing. Has anyone else had this problem or could point me in the right direction?
    Search this forum. Lots have had this issue. Likely need to reset the yaw control due to new or lifted suspenion.
      Thanks Piggy I'll have a look. I have replaced a ABS sensor and my mate thinks that that may have something to do with it, height difference in the new sensor or rust on the pickup wheel.
        Sounds like someone damaged the ABS sensor or did not mount it properly
          I have had a friend with a similar problem with his Hilux when he replaced the steering rack. I have changed the rack and moved the steering wheel to suit and that I think is where my problem lye's, he said the vehicle is too cleaver for it's own good. I am getting my mate to have a look next week.
            Did you end up getting to the bottom of this BonesXU1? Got the same issue after replacing cvs
