Weird buzzing noise behind dash when starting car
Sounds like an aftermarket air compressor. Like an ARB. Most likely installed under the seat.Last edited by amts; 30-01-2023, 11:31 AM.
Did you happen to work this one out? I have a 2008 petrol model doing exactly the same. No air compressors on board
https://www.pradopoint.com.au/member/76146-drzel
G'day!
2006 Grande does the same. It appears to be from the ventilation distribution unit behind the driver's side dash. When you select a different mode, the buzzing fires up again but the mode doesn't change. My vents are stuck on feet/floor mode, even though I've selected face. I think the dash will have to come out to replace the unit. Gonna hurt the hip pocket I think!
