Hello, new here, from Dili, East Timor
I own an australian market 2009 KDJ120R, 1KD-FTV turbo diesel engine, A750F gear box. 153,000 Km.
3 Years ago I changed the gearbox fluid using a gearbox fluid changing machine. It used almost 20 litres of Toyota ATF fluid. the old fluid was dark but didn't seem too bad.
Begining of this year, engine started blowing oil from the back of the valve cover. The mechanics here in Timor declared that it was worn out piston rings. However, there was no blue smoke coming out of the tail pipe, only black smoke in heavy acceleration.
Sudenlly, I started hearing a loud whining when accelerating, loos of power noticeable on hill climbing and gearshifting at higher RPM. Until the car sudenlly went into limp mode.
Ordered genuine new Turbo and new injectors from abroad, installed everything, with my newly acquired scanner cleared all errors and inputed the compensation codes and all seemed fine.
But not really.
Engine starts normally, no more black smoke at all even when trying to accelerate hard, but RPM are slugish to increase and gearshifting, even on a flat road, happens at 2400rpm or above, if pressing the accelerator up to 3200RPM and takes forever.
Scanner shows no DTC in any system.
What could be causing:
1. Slow revving up? Engines seems lacking torque.
2. Slugish gearshifitng? Need ATF changing and gearbox filter cleaning?
3. Could it be any problem with the Transmission Range Sensor although not showing in the scanner?
Any help is most welcome
Best
Joćo Tavares
But not really.
Best
Joćo Tavares
