Hi All
2004 GXL V6 auto with a weird switch problem after a battery disconnect. I installed the battery and normalised the switches, but the rear left passenger switch has an issue. All was good prior to disconnect but now that window will not go down by its door switch. The drivers switch will operate that window up down without issue. If I use the driver switch and put that window partly down and then use the passenger door switch to operate the window it will go up but not down. Any ideas on how to rectify that?
