Prado Key Type
  • Prado Key Type
    Hi,
    Does any1 know if the 2003 Prado use the 4c or 4d transponder key?
    I believe that the change over from the 4c occurred in 03 but I am not sure and would like to buy a replacement key online but am unsure of the type.
    Re: Prado Key Type
    Hello,
    I'm driving a 2003 (European) Land Cruiser / Prado 120 and I recently had to change the housing of my key (the plastic was broken, just above the metal part). I wasn't also sure which model I had to order. So I sent a picture and the dimensions of the blade and I've got the right one. Now I have a regular key (without logo) and a key that flips in (with logo). You have to transpose the electronic part inside of the key, but with the flip-in model you must seperated the transponder and replace it because otherwise the distance is to much between the key and the dash. I found the replacement on Ebay in France and The Netherlands. I only had to cut the new keyblade with a keyrepairer.
    I hope you can do something with this info.
    grtz
    Dirk
    Powered by Toyota, Controlled by Me.
      Re: Prado Key Type
      Originally posted by BiestJen
      Hello,
      grtz
      Dirk
      Thanks Dirk,
      I am not sure of how the years between the intro of the 120 Pardo and the Cruisers translate.
      I know the key dimensions but i need to know the transponder type as I am going to program a new key from scratch.
      Thanks for your help anyway.
        Re: Prado Key Type
        Any1 has any info on this? 4c or 4d?
          Re: Prado Key Type
          Look at your existing key.
          No dot is the 4c transponder.
          Mick
            Re: Prado Key Type
            Mick
            Thanks Mick
            This dot would be on the original master and 2nd key that came with the car?
            I think I only have the second key.
              Re: Prado Key Type
              In Australa it's only on the master (non-remote) key.
              The remote keys have an "L" stamped in the same spot but I can't confirm if this is related to transponder ship type.
              You may have to take an educated guess and buy a key (or one of each type) and just try to program it.
              Toyota blank transponder keys can be bought very cheaply (Like $20US out of China or the US, have a look on Ebay or do a Google search.)
              If your budget stretches you can also get a key programmer that plugs into the vehicles diagnostic plug.
              Mick
                Re: Prado Key Type
                Mick
                Thank you. Will do
