Hi all, I have a 120 and would like some info on building false floors with draws for storage.
False Floor information needed
Re: False Floor information needed
have a look here richchris for a few ideas. cheers samo viewtopic.php?f=4&t=1268&st=0&sk=t&sd=ahad an 03 gx 120 with some gear now got a 2013 bt 50 GT auto some ARB gear.
Here's mine http://www.pradopoint.com/viewtopic.php?f=18&t=6245
No drawers but a folding false floor if that's any help.
Craig______________________________________________________________________
August 2008 D4D Auto, Grey, Uniden UH-013 UHF, custom cargo shelf, colour-coded ARB Sahara bar, Hella Rallye 4000 Compact 55W HID driving lights, dual batteries, LOUD Stebel air-horn, in-betweeny roof racks
One more for the pot...I wanted a false floor so I could bolt down a fridge slide and an aux power pack, but have it all completely removable. And I wanted the fridge slide to stay as low as possible, so I didn't want drawers. I saw those 4 cargo tie-downs, so thought I could use them to lock down onto. What I ended up with was 2 layers of 12mm MDF with sliding-bolt latches that engage with the tie-downs. The 2 layers are only so that I could recess the sliding bolts - if you didn't mind them standing up above the surface you could probably get away with one layer. It's hinged down the middle with a piano hinge to make it easier to put in and take out. Mine stops at the back seats and does not require them to be folded up, but it could extend further forward if you wanted it to I guess. It may be a little rough in places, but it does the job well and I'm very happy with the result. I know this isn't exactly what this thread is about, but thought I'd throw it in anyway.
This shows how the underneath layer is cut away to save weight - it's only really needed around the edges, where the latches are, and where the hinge is.
This shows one of the latches attached to the underneath layer, and reached thru a cut-out in the top layer.
The left rear corner, showing how it extends out into the "bay" behind the wheel arch. It has to do that so it will be over the tie-down.
The aluminium strips further forward are where the aux power pack is tied down.
The right rear corner showing the fridge slide, and the piano-hinge down the middle.White 08 Standard with ABS/cruise option pack, D4D/6-man, std 6" steel rims with Cooper AT3 235/70R17s, added roof rails, bullbar, towbar, ScanGauge II, custom-built aux power pack, Bushman multi-capacity fridge on slide, on DIY removable false floor. Often towing an Ultimate camper-trailer.
