was asked by a mate the other day to make up a sand flag connector. i had a look through the shed and found a few things. all you need is a male and female 3/4 inch QDS hydraulic fittings, 1/2 inch UNF nut, M12 x 25 mm blot and ut plus a welder. The UNF nut was welded on to the female end of the fitting, this allow the sand flag to screw straight in for a quick disconnect, the m12 bolt was welded on to the end of the male fitting, this in turn is bolted on to the mount where the sand flag is to be attached. took about 10min in all to knock up. this will be much stronger then the brass air fitting which i have seen used and break off every time you hit a tree with the flag.
connected
disconnected
end view
another end view
cheers samo
connected
disconnected
end view
another end view
cheers samo
