Rear Parking Sensor Installation
  • Rear Parking Sensor Installation
    Hi,
    I am just about to install an aftermarket rear parking sensor kit to my 120 series Prado. Can any one assist me with the correct spacing I should use between the sensors.
    I have a tow bar fitted and it has been recommended to space the two inner sensors wider apart to avoid interference with the bar. Is this an issue with the Prado?
    If anyone has a factory fitted kit, knowing the distance between the sensors would be a big help.
    Sorry can't help with spacing but maybe it's too late to say this but a reverse camera is more effective without being annoying (no beeping).
    If no one replies, maybe find a Prado with reverse sensors at the shopping centre carpark and measure that.
      Thanks amts. Will be getting the reversing camera as well. Unfortunately my wife has a special skill for backing into things and need to install every device known to man to minimize future damage.
        x 450 x 500 x 450 x
          Perfect. Thanks D4D
            That's centre to centre
              I would go wider with the outside sensors. Something like 500 x 500 x 500. That way you will pick up things just to the side as well. We have the standard spacing and it is scary how close you can get to the side without any warning.
                If they aren't smashing into things they are yapping at 100 miles an hour and distracting you. Someone should blow up women
                (refer to my build for my experience with pillares and yap-yap-yap.)
                  Thanks for the insight mjrandom. The wider spacing makes sense. I think I will that a go.
                    did this get done?
                    couldnt you just use the predrilled holes that are in the steel section under the bumper skin. thats what i was told they were there for
                    [size=1][color=#990000][b]--> Macarthur District 4WD Club Member <--[/b][/color]
                    ::2005 Black Grande Petrol V6::2 x PP Stickers::ARB Deluxe Winch Bar::IPF Spotties + Fogs:: Dual Battery, ABR DBi120 Isolator & Volt Monitor::ARB Portable Air:: Rear Drawer Unit::Trek Table::WAECO 40Lt::WAECO Raps R12U::AMTS Rear Tyre Spacer::HILUX Washers::UHF::Prodigy P3::Stebel Air Horns:: Inverter::CouplerTec Electronic Rustproofing::OEM Roof Racks, Towbar, Hard Wheel Cover::REAR CAMERA to factory GPS::[/size]
                      Hi,
                      Old thread I know but I'm curious as to how water proof the sensors turned out to be?
                      I have them on our 2WD but that doesn't go under water...
                      Malcom
                      Prado 95 TX turbo diesel
                      LC100 GXL turbo diesel
                        Hi Malcolm,
                        For normal city running they are fine. I haven't taken my Prado off road for some time so haven't tested them fully submerged.
                          Hi Malcolm,
                          I've had them on an Estima for close to 10 years and the sensors are still working fine, so for rain and car washing they are fine but I've never tried them out under water...
                          Someone must have done so?
                          Malcom
                            Mine have been under water a few times now but I didn't consider that they worked properly in the first place. Having said that they are no worse and sadly no better after a drink.
                              Not entirely sure that that helps me
                              Malcom
