I wanted a twin wheel carrier rear bar but felt that the commercial ones were just too expensive for me to be able to justify buying one. Someone posted a link to the Rijidij wheel carrier kit website and having seen that I could get the stub axle etc. I decided to have a go at making my own rear bar.
I decided to base the bar around a 125 x 75 RHS main section and was torn between 3mm and 4mm wall thickness. 3mm seemed as though it would be OK but in the end the decision was taken out of my hands - the only RHS I could get locally this size (and 1.7 m long) was 4mm.
I didn’t want a bar that was straight across the back so first up I cut two slots to give the bar a 5 degree forward bend either side. I made the centre section the same width as the rego plate (380mm). I then tack welded a 75 x 200 x 5 plate to the front edge. Two 13mm holes allowed this to be bolted to the OEM tow ball mounting point.
I bolted the bar up as shown below:
