Well since i am a boilermaker-welder and seeing Trekriders thread on making a wheel carrier i figured why not make my own as well, plus it would be a lot cheaper then buying one. All the steel i got from work for free so it ended up being very cheap to make. I wont go into too much detail as it is almost the same design as trekriders only things i did different was flush mounting the indicators and didn't use the rear bumper i cut some 1.6mm steel plate and welded it up to cover up where the rear bumper was. The handles for locking the wheel i got from work as well, we use the on our pipe rotators so not sure how much they cost. So the build was very cheap as the only things i had to buy were the sub axles, reverse lights, indicators and pay for the powder coating. I plan to modify it a bit don the track by putting gas struts on the arms for the wheels and doing away with the locking pins that hold the arms open as i find them to be a pain. So here are some pics of the build. Never posted pics before so hope it works.
D.I.Y Wheel Carrier
Brett,
Looks like a top job. Should make them for sale on PP.
HazzaSilver 120 Series Diesel GXL 2009 with Option Pack 2, king Springs 2" Lift with 'H' front spring, MT ATZ 4-RIB, Dual Battery, Deluxe ARB Bull-bar, Winch, Towbar, Anderson 50 amp plug at the rear, Weather Shields, Bonnet and Head Light Protectors, Rubber Mats inc Cargo mat, UHF Ariel, Portable Uniden UHF plugs into areal, On-board ARB Compressor, Brains Black Box TG150 Protector, Rear Black Duck Seat Covers.
I mounted the bar to the car by welding some 12mm nuts to some 3mm thick washers then feeding them inside the rear chassis and lining them up with the holes in the chassis screwing a bolt in to hold it while i welded the washer to the chassis, i didn't get any photos of that but when i take the bar off next time i will take some photos.I am going to add 2 more bolts to stiffen it up a bit at the moment there is only 4 12mm bolts holding it in place 2 on top of chassis and 2 under neither the chassis, i want to add one into the side of the chassis on each side. I plan on getting a price from work for all the steel and if its cheap enough i might remove my bar and make a jig to suit then make a few to sell, i will make a few changes as i since i finished it i can see some easier ways of doing thing which will make it cheaper and use less material.
Hazza
Nice job Brett!
Cheers guys, not sure on how many hours it took i only worked on it over the weekends and not wanting upset the people around me i did not start making noise until after 12 on the weekends, and i am thinking about making some more just depends on the cost of steel. Making a jig means i can build them faster i also made templates of all the bits as i went along so that will make it easier as well.
Great work Brett - and thanks for contributing a great posting to the forum.NOW FOR SALE!!! - 2004 Silver GXL 3lt 4spd Auto - ARB Bullbar, Safari Snorkel, Redarc Dual Battery System, Cooper ST MAXX, Dark Tint, IPF900XS spots, Raised Bilstein/Kings Suspension/Firestone Airbags, Autosafe Cargo Barrier, Sandgrabbers, Rola Roof Rack Stuff, Insect Screen, Dust/Wind Deflectors, Sheepskin/Black Duck Seatcovers, GME TX3510, ARB underbonnet compressor, Allied Hammer Rims, ARB UVP, [url="http://www.pradopoint.com/showthread.php?18043-Rock-sliders-steel-side-steps"]AJ Sliders[/url]
