DIY Boost Gauge for $60
  • DIY Boost Gauge for $60
    installed boost gauge today, very easy install, takes around an hour
    Boost gauge $40 from local spare parts shop and has mulitcolour back light
    the mounting pod cost $10 from supercheap drill holes in back to suit you gauge, this one was a speco brand
    [/img]
    you also need about 2.5m of 1/4inch vacum hose, and a 1/4 inch T piece. attach to intercooler on inletmanifold side using tee piece.
    [img]
    run hose along the firewall and through into the cab up to the steering column, i wired the backlight for the boost gauge by taking power off the 10 amp ingition fuse in the fuse box and earthing to the metal in the dash
    attach the gauge to the steering column with doublesided tape and the finished product is
    and this
    cheers samo
    Beauuuudifullllll 8)
    My Rig Buildup [url]http://www.pradopoint.com/viewtopic.php?f=38&t=4918[/url]
      Can I make a small suggestion?
      Tee of between the boost sensor and the small damper, this is;
      a) More accurate as it reads after the the throttle body which acts a
      restriction.
      b) The damper reduces/stops needle shake at idle/low boost.
      Mick.
        looking good
        W. C. Fields (1880 - 1946)
          replumbed gauge as mick said and it does reduce needle shake at low boost but i still get shake at idle. thanks samo
            The only way to stop the needle shake is to get a quality guage like
            Auto Meter or VDO.
            I went through this issue on a previous car, 3.0lt patrol.
            What psi are you seeing..Best i've seen is 30psi on the patrol
            07 GXL D4D Auto
            265/70/17 Cooper St, ARB Dual Battery, IP900XS Spots (crap), Black Widow Draws, Cargo Barrier,Billy Lovell combo, polyairs, reverse camera,
              i havent played with boost at all, only snorkel and air filter and standard exhaust. i get 12psi, thats ok with me.
                Re: DIY Boost Gauge for $60
                Well I finally got aroud to installing my boost gauge, When I was looking at which vacuum line to hook the gauge up to I noticed that the picute supplied by Mick L shows the vacuum lines from the red (????) goes to a diferent location that mine ( see below pic's for better explanation) Mine from the top of red (????) goes to the intercooler. I don't whether miy lines have been changed or the ones that Mick L shows in his photo's or whetehr it matkes a difference at all.
                http://s539.photobucket.com/albums/f...acuumLines.jpg
                http://s539.photobucket.com/albums/ff35 ... mLines.jpg
                Mine is the 1st photo and the 2nd one is from Mick L.
                Greg
                GXL 3ltr TD Auto and Alloy Bullbar , IPF Extremes, Dual batteries, Safari Dtronics Chip / snorkel,radiator bash plate,uhf, Mandrel Bent Exhaust 2inch Lift & Gdyr MTR 70 series play tyres on steelies
                  as long as it is on the intercooler side, it should be fine,
                  as this is the pressure you are trying to measure
                    It makes no difference, the " red thing" is a damper. The sensor it's plumbed to on the intercooler is the vacuum/boost sensor for the ECU. By teeing in the boost gauge between the damper and the sensor, needle shake at idle and low boost is greatly reduced.
                    Mick
                      Hi, just a quick question for some one in the know, i bought a autometer boost guage to fit to my d4d, now i just wanna pick someones brain as to is it the same place for the tee piece on the d4d as the old diesel as in pipe? I would appreciate if a piccy could be shown of the exact one to tap into, cheers
                      08 GXL Diesel Auto,ARB bar/roofrack, ATS liftkit
                        On the intake manifold side (Passenger side) of the intercooler are two sensors (attached to the end tank of the core) The one furthest to the front of the engine bay is the ECU boost sensor. TEE into it's line.
                        Mick
                            Thanks Mick for the information...very much appreciated, cheers
                              Hi,
                              I like to know if you guy's get a vacuum reading on the boost gauge? If no, why is that?. I got one installed on my 1KZ-TE, and one of my mate ask me how come my boost gauge doesn't read vacuum?, and I just answer maybe its just a diesel engine different from a petrol engine. Just want to really know what the answer is. Unless there is something wrong?
                              Thanks guys,
                              Chubbo
