Oky doky, here we go, got down to business and installed the Lightforce 170's yesterday and here are some picks of the work myself and a HV sparky mate got up to amongst Macca's and Jacks and Dry hahaa.
Ok, first to fit and drill the holes for the 170's @ a 10.2mm hole plus another hole just to the rear of this hole for the wires to pop into the bumper, pics for that later.
Next was to find and cut into the Hi Beam Feed (red and white wire)
The relay setup for spots and rear light just behind the main battery next to firewall for now
The main lights wires, fed up behind battery, up and into the hole at top of radiator mount
The firewall entry, in between the blue and green you can notice the heatshrink cables. Nice seal too.
The dash mounted switches from Supercheap, with LED's, not too bright either, great look Green is for the spotlights and yellow for the rear worklight, but that wiring loom is curled into the foot cavity to the right for now until I have time to run the cable down to the rear, but the relay and switches are live.
right amount of cable ready for joining to lights, after lunch of course haha oh and another jacks's
Wires joined under bullbar, to save rubbing from bonnet
Closer look, the top of the holes are filled with sikaflex to stop wire movement against bullbar, and all holes have been flapper wheel sanded to smooth off.
Final check and we fired it up...... click......click...........no lights !! arhhhhhh :shock:
How about a fuse chaps, what do ya reckon ! :roll:
Tadaaaa! we have light !
