SA Automotive Engineers
Now with 3BAR MAP sensor & 18PSI Boost![/COLOR][/SIZE][/I][/B][/CENTER]Tags: None
Re: SA Automotive Engineers
Out of curiosity, what mods are people doing that require a engineers certificate?
Thanks Mick,
Found the code here: http://www.legislation.sa.gov.au/LZ/...999.236.UN.PDF
So, a standard tyre of 265/65 makes the sidewall around 172.25mm, and a 270/70 is around 185.50mm, a difference of 13.25mm or 26.5mm for a tyre.. Is that correct?
Does a OME spring and shocker upgrade warrant a trip to the engineers?
Code re tyre legislation below:
Code:Despite the requirements of any other regulation or rule under the Act, a motor vehicle that is required to comply with ADR 24 or the tyre and rim selection requirements of ADR 42 may be— (a) equipped with tyres other than those listed on the tyre placard fitted to the vehicle, provided that— .... .... (ii) the overall diameter of a wheel and tyre fitted is not more than 15 millimetres greater than that advised in the Tyre and Rim Standards Manual (issued by the Tyre and Rim Association of Australia) for the largest tyre size listed on the placard and not more than 15 millimetres less than that advised in the Manual for the smallest tyre size listed on the placard....
thanks, what $$ do they charge for this (assuming its just to certify the tyres)? How involved is the process?
I was speaking to Peter Young who runs Alltrak 4WD on South Road last night and asked him about engineers and who he recommends and he mentioned Doug Potts, the same fella who did the engineering work for Team Piggy. Just did a search on the net and found an updated list of Engineers who have been recognised by the Department for Transport, Energy and Infrastructure here in South Australia. A few names have changed since Mick posted his from above:
http://www.transport.sa.gov.au/pdfs/..._engineers.pdf[COLOR=#000080]Nick[/COLOR]
Just an update to the link for the list of Automotive Engineers
http://www.sa.gov.au/upload/franchise/Transport,%20travel%20and%20motoring/Motoring/Vehicle%20Standards%20and%20Modifications/MR426%20Chartered%20Professional%20Engineers%20Fac tsheet.pdfLast edited by amts; 01-11-2013, 05:20 PM.
