Fog Lights switch
  • Fog Lights switch
    hey, I have a Prado GX, does anyone know if by fitting the GXL indicator stalk and plugging in some fog lights whether they will work? The wiring for the fog lights is already there at the bumper end, they just have to be plugged in.
    I have seen in another forum that it works on the Landcruiser 100, just wondering if anyone has done it here?
    thanks
    150 Charcoal GXL V6. Stock standard at the moment
    Re: Fog Lights switch
    I would say yes, as I did the same thing on our Corolla.
    We also had to put a relay into the correct spot in the fuse box and it all worked fine.
    Check your fusebox as it should be labelled for a relay, but it may or may not have one fitted.
    Cheers, Mat
    June 2008 Prado GXL D4D Auto with Option Pack1, ATZ Mickey Thompsons, Indash Digioptions DVD/CD/SatNav. running OziExplorerCE, Reverse Camera, IC7000 Icom VHF/UHF/HF, Codan 9350 Autotune, Uniden UHF CB, ARB Color Coded Steel Winchbar,X9 Superwinch, Hella Rallye 4000 HID's, King Springs 2 Inch Lift, Milford Barrier, Redarc Dual Battery System, Drawers and Waeco Fridge...........and August 1979 Landcruiser FJ40 Shorty, B.F. Goodrich ATZ, ARB Steel Winchbar, Heaters, Wipers, Headlights!!!
      thanks Mat! It does work. Replaced the indicator stalk with the one that has the fog light switch, plugged in the relay and hey presto it works like a gxl, dash board fog light indicator included ! Makes me think the wiring harnes is the same, at least for the GX and GXL !
        Sounds good.
        WOuld you happen to have the part number & cost for the stalk ?
        Thanks,
        Brian
        Ex Govt KZJ120 GX. Toyota bar, dual batteries, Billies & OME springs, TX3440, Cooper ST's on 7.5 steelies, black duck seat covers, Dtronic, & more to come...........
          Part number is 8414026150
          price was $156.54
          A little expensive but as I already had the fog lights i didn't concern me
            price was $156.54
            Cheap compared to many others though.
            The generic term "fog lights", when in some discussion - might like to bear in mind 'front fogs', or 'rear fog' since both exist.
            NB - The lower red 'dummy' lamps on Prado's are a complianced rear fog lamp, DIY'ers should only connect the function as such. And of course you need to achieve focal point.
            [b][color=black]Purchase a [/color] [color=red]hazard-warning triangle[/color] [color=black]for your 4WD to improve the ‘warning-time’ given to approaching traffic, at both crash scenes and vehicle breakdowns. Store it in the boot. I suggest Hella Part No. 2901 - $70, or from Auto Parts Shops, - supplier "Prokit" - Item No. RG9212 - $20. A World/Euro standard triangle device exceeding AS3790 triangle performance requirements.[/color][/b] [url]http://www.dpi.wa.gov.au/mediaFiles/lic_drivesafe4.pdf[/url]
              Although I have the OEM front factory fog lights, I do not have a fog light indicator in the instrument cluster :roll: Am I missing a fuse or some other piece?
                No I don't think so - at least on the 90 series GXL which also comes with standard fog lights there is no indicator that they are on other than the fog switch indicator itself.
                Richard
                2011 GXL TD Auto Prado Silver
                  Hi, can anyone tell me the part number for the fog light relay for a 2007 prado? Either that or a Narva part number for the same thing.
                    revman I was just down at toyota yesterday ordering the surrounds to mount my fog lights asked them about the relays for the lights and there are two different types depends on which model prado you have there not cheap looking at over $100 havn't tried narva yet but sure there is a cheaper way to go.
                    Cheers shane
                    03 Prado GX TD Manual
                      Cheers shane
                      Or you could just get your hands on one of the 10,000 discarded front bumpers complete with fog lights where owners have fitted bullbars. If you're paying over $100 then you're paying too much. I've got one hanging from the rafters in my shed.
                        Prado 120 fog light relay.
                        Hey check this out. I was quoted $92 from Toyota for the relay. I found them on Ebay from the U.S.A at us $4.90 each. I bought 2 (one for a spare) and with postage and currency conversion they cost me au $12 for both.
                        .....and yes, the green fog light indicator on the dash does light up.
                        Relay part number AJ51, Denso brand.
                          Fitting fog lights to a GX 2004
                          Hello All i have a GX 2004 turbo diesel Prado and a standard toyota bar that came with no fog lights.
                          I have bought a set but do you know if i can just replace the head light switch on the column and plug the lights in or do i need a whole wiring harness. The plugs are there for the fog lights but not connected to anything on the bar end. Also do the rear fog lights work or is it not connected either.
                          Nigel
                            Nigel
                            The rear fog lights are not connected on any of the Australian models, they are a reflector only. If you search you will find this has been discussed a number of times.
                              thanks for the info guys ill be getting a light stick then i think will make the dash work as well. that will be cool.
