Rear Door Dropped and not lining up???
This topic is closed.
  • Rear Door Dropped and not lining up???
    Hi Guys,
    I'm just wondering if anyone has firstly had the problem of the rear door dropping and not lining up, and secondly, if so how to fix the problem apart from the obvious of adjusting the door mechanism. I have tried the old trick of jacking the door up but all this is doing is lifting the rear of the car and I can see that eventually the rear window will break :shock: .
    Does anyone have any solutions to this problem or is it a job for the dealer at the 80K service :? .
    Pico.
    Re: Rear Door Dropped and not lining up???
    Try the search feature.... more than one thread running on this....
    Here's one to get you started:
    http://www.pradopoint.com/viewtopic....r+door+sagging
    Mick
