What is the best wasy to attach a carge basket
  • What is the best wasy to attach a carge basket
    I purchased a generic cargo basket that I would like to attach to my Thule cross bars, which sit on the OEM roof rails? What is the best way to secure the basket to the cross rails? Cheers.
    Re: What is the best wasy to attach a carge basket
    A u-bolt fitting kit usually available from your local roof rack supplier.
    http://rhinorack.com.au/AccSubCategory_ ... 98_35.aspx
      I used the fitting kit that came with my basket (shown in the bottom right of amts link) for the heavy duty bars. I have seen people install these kits with the nuts at the top. I installed mine with the nuts at the bottom but I also chucked the supplied plastic finger moulded nuts and used nyloc nuts as I didn't want to be checking and tightening every time I stopped on our trip. Also with the brackets facing up IMO there is a huge risk of items rubbing against the excess thread and damaging your goods in the basket.
        I am with MDS69 with one addition: with the nuts facing down use Loc Tight AND tape the 2 nuts on each bracket together so they can't come undone on corrugations - survived 6000 km of dirt including CSR corrugations. Neil
          I intend to use the basket on long camping trip but take it off when I get home due to the height restrictions in parking lots and the noise factor, is there an easier on/off solution?
            Sadly I don't think so.
            I think there is a trade off to being secure for the type of tracks we encounter like 404pug mentioned to ease of installation/removal.
              The U clamps can be a bit fiddly especially if you put the nuts on the underneath. ( which is the only way to go IMHO )
              A good stepladder helps. I find it only takes 15 minutes to get the basket on/off
              BTW - there are different U clamps for the Aero bar and the HD crossbar - the Aero clamps are wider and flatter.
              Cheers, Wayne
                Note that the Thule crossbars may be narrower than a Rhino Aero or Sportz bar. You may find that the U-bolt clamps for the H/duty bars may fit more snuggly.
                Or buy a Thule U-bolt kit (MA 3035) --> http://www.thule.com.au/news_detail.php?news_id=1
                  I guess it it the U bolts that I am looking for, will have to research that and look at buying them from the US on my next trip over.
