D.I.Y Windscreen wiper jets upgrade
  • One of the first mods I read about on PP, still haven't got around to buying the washers.
    Big Dog
    • Originally posted by BigDog816 View Post
      You are missing out mate!!!
      • This was the very first mod I did, couldn't be happier with it.
        03 Grande, V6 AUTO.Red Metallic, Sovereign bar,Narva driving lights, GME uhf.
        Brtidgestone D697 ltrs,(got more than 75000 kls out of D694's) Black Widow Rear drawers & Cargo barrier,with shelf & divider..Elec Brake controller,now tow a 24ft "Spaceland" 2012 caravan.
        [B][I]Bitumen - A blatant waste of taxpayers money![/I][/B]
        • I'm trying to find the start of this thread, but I can't seem to find the original instructions. Am I missing something here?
          [b][color=#800040]2007 120 GXL D4D 6sp Man[/color][/b]
          • Couple of instructions from post #142 onwards.
            The original poster left the forum and deleted all his posts. He is now back though.
            • Thanks! Just ordered a couple ;-)
              • Originally posted by ToeEdge View Post
                Hey mate, have a gander at my rig build, i have done a detailed write up on a super easy and quick way to change these out! will save a lot of sweat and profanities :-)
                • Originally posted by Ghost View Post
                  You don't have to cut off the clip when you lift the front of the jet up. You insert a cable tie in the gap and then pop the rear of the jet. Then the whole thing pops out.
                  • Ordered mine today. $22.60 ea I will try the cable tie trick tonight... Thanks Andrew
                      True you could do it this way, however also with the way i did it you damage the original jet by twisting with pliers, so i personally was not fussed with keeping the clip.
                      • im sure the method could be modified more to not damage the jets, i will leave that to someone else :-) atleast my method takes 1/5th of the time and is cheaper in the end due to not requiring the lining clips..
                          Oops, didn't go back far enough. Try post #85.
                          This reminds me I've got to get mine done as well. The ebay cheapies aren't that crash hot and uses a lot of water with lopsided coverage.
                          • All done. What a breeze! each jet took less than 2 min to replace, Like everyone else, a huge improvement in spray coverage. No damage done to the old jets. the difference in the jet nozzles are quite different as you can see in the pic. Thanks Pradopoint!!
                            • Did mine today. Funny thing is, when I picked the new jets up at Toyota, I mentioned it was a mod I saw online. Sales guy says.... "Pradopoint.com?".
                              Ahh yeah ;-)
                              • I picked up two of these jets they have a part number of 85381-0K010.
                                Part name: "Nozzle, FR WASHER , RH."
                                Is there a left hand and a right hand verison of the jets.?
                                Both my part numbers say "RH" and I noiticed the washer jet is offsided to the right side.
                                Dont want to put them both in if i have to return one for a left hand jet.
                                gumboot
                                [B]Robert
