hi
I have a problem with the air lift on my 2003 prado
the air susp off light is flashing constantly and there is no control to lift or drop
it will drop right down to the rubber stops overnight and if you leave it running it will lift ok in the morning and its ok
but if you drive straight away it doesnt lift and bangs on the rubber stops
It started doing it but you could rock the switch and it would work then stopped I have removed switch cleaned it up as it had oxidised from to many cups of coffee .
one lamp had gone so replaced it light still flashes
is there a reset for the lift
thanks phil
thanks phil
