Originally posted by 1coolbanana
View Post
I was in contact today with Mitchell Bros, and I asked them if their 'retaining solution' was fitted to my vehicle - seems they do NOT do anything in terms of retaining work on the airbags. They claim the only time the airbags dislodge is if the wrong shock (i.e. too short) is fitted.
They recommended fitting Firestone replacement (longer) airbags if you want a big lift, but otherwise longer travel shocks will do the job.
820mm (or a little lower) looks about what I will set mine to.
Did some measuring of the front tonight. Currently sitting on 740mm using the middle circlip on the Bilsteins (no idea what model spring has been used though - not a long or strong one to only have that height I'm guessing), full droop is 865mm, so I can go to 800mm at the front with 60mm droop still available. Will be happy with 795 or so after settling.
I assume the CV angles aren't too bad if the front is sitting at 800mm? (Forgot to have a look at them while the front was jacked up.....).
