Originally posted by Peterpilot
View Post
Grande Airbag Retaining after a Lift
Test fitted the spacers tonight. Had to seek advice from Peter about how to deflate the airbags.
The spacers fit perfectly. The cross drilled hole is a bit too high. The bolt would hit the airbag base which has a lip that turns down. I'll look into grub screws next week.
I could move the hole down but the airbag pin is pretty short and stubby. I had the rear at full droop and it doesn't look like it was going to dislodge. I tried levering the pin out and it wouldn't come out. So with the spacer in, it would be even less likely to dislodge.
Originally posted by waltec View PostHi Andrew,
Why is it every time I read one of your posts, my wish list grows?? Or should I say my NEED list!! Please add me to your list, and add it to my order!!!
Ur better than an ARB store.
Thanks Mate
Matt
craigm likes this!!!
Originally posted by amts View PostHere are photos of the test fit. Found the right size grub screw which requires a ball-ended allen key to tighten up.
[ATTACH=CONFIG]7277[/ATTACH][ATTACH=CONFIG]7278[/ATTACH]
And here's the finish product with all stainless steel hardware.
[ATTACH=CONFIG]7279[/ATTACH]2004 V6 Grande. BLACK -
Let me know when you want some funds.Marc, 2003 Grande V6, Just a Bit of Stuff Done..........Work in progress.
Originally posted by amts View PostCheers Craig, Shan. Haven't installed mine yet.
I'm waiting for the prototype SST to come from the US. It got shipped today. So for those who already have the SST, I can ship immediately."Sure it’s quiet, for a diesel, but that’s like being well-behaved… for a murderer."- Jeremy Clarkson
Someone should start an SST rental business!
Unlikely for most of us to ever need one more than once and that will be for fitting the spacersMarc, 2003 Grande V6, Just a Bit of Stuff Done..........Work in progress.
