Anyone got Kings KTFR-101HD springs fitted?
    Rusty62
  • Rusty62
    replied
    Originally posted by mackayvx View Post
    On a final note... It is so hard to find a good wheel aligner... so many amateurs out there thinking they are professionals!!!
    Have a great aligner here in Brisbane. Been using him for over 20 years.
    Rick's Wheel Alignment & Tyre Service.
    Rusty.
    Leave a comment:
  • craigm
    Addicted PP Member
  • craigm
    replied
    Dont think you'll need the spacers Matt. I'm running the 101HD's up front on my 120 (Bar, Winch, Dual Batt, compressor) and she sits pretty high with no sag for the last coupla years...
    Leave a comment:
  • matt150
  • matt150
    replied
    Originally posted by gumboot View Post
    I run HD's all round and very happy with them.
    Question. I'm fitting Bilsteins and the Kings HD next week. I have steel bar, dual batts, lights etc. no winch yet. I have medium TD coils at the moment with a 6mm spacer. Thinking and refitting the spacer with the HD's to compensate for any Spring sag, thoughts ????
    Leave a comment:
  • gumboot
  • gumboot
    replied
    Leave a comment:
  • mjrandom
    Out of control poster!
  • mjrandom
    replied
    Gods yes. I have had about 7 places frig with my Clubbie and none were good.
    Good to hear it is sorted now.
    Leave a comment:
  • mackayvx
  • mackayvx
    replied
    Ok just a little bit of feedback.
    4 weeks ago, I removed the KTRR 102's from the rear and fitted the KTRR 102 HD's.
    In the process of that I discovered that the leaky air bag was actually a split air line - so I was pretty happy simply repair it and not throw them out.
    I hadn't made it around to removing the front struts (KTFR 101 H's) to move the clip position up to the middle... which I am actually glad about.
    So previously the measurement's were
    FL - 790 FR - 785
    RL - 805 RR - 795
    Now with the HD springs in the rear, air bags on 5PSI and the front struts on bottom clip... I have achieved...
    FL - 790 FR - 788
    RL - 820 RR - 822
    So that is loaded with the Outback drawers, 80L fridge, Recovery gear & Tools.
    Now the HD's are in the rear, the H's in the front seem to be behaving them selves a lot more and the car doesn't feel like it has as much body roll as before.
    I think the car would be awesome with HD's in the front as its got all the fruit there short of a steel bar.
    So I have decided that if Im going to remove the front struts to move the clip up to the middle for the H's, I may as well fit the HD's and be done with it...
    So thank you PP crew, my suspension is now sorted...
    Leave a comment:
  • mackayvx
  • mackayvx
    replied
    Originally posted by Ghost View Post
    If you need a hand brother, just give me a yell, any excuse to catch up and have a few bevos
    Mate I will do that. I know your away until after easter so ill speak too ya then. Thanks bud.
    Leave a comment:
  • Ghost
  • Ghost
    replied
    Leave a comment:
  • mackayvx
  • mackayvx
    replied
    No worries Peter.
    That all seems pretty straight forward and I think the front height of 800 is achievable but moving the clip up to the middle position.
    Ill chase some 'HD' rear springs down and fit them up.
    Im just hoping the 'H' springs on the front will hold up to the weight.
    Leave a comment:
  • Peterpilot
  • Peterpilot
    replied
    My current set up is the same as what Gumboot had before he converted to HD's all round.
    On the vehicle at the moment are Bilstein stuts and shocks with KTFR101-H (Bottom clip) on the front & KTRR102 with busted airbags on the rear.
    Measurement as of today are -
    FL - 790 FR - 785
    RL - 805 RR - 795
    So my question is now ready to be asked.
    After i fit the new KTRR102-HD's to the rear, would I be able to retain the KTFR101-H's on the front?
    If so, which clip position would you go for?
    Hi Drew,
    Assuming you achieve a similar ride rear height to Gumboot with the KTRR102HD springs of 820mm loaded, then you would need the front to be about 800mm.
    To raise the front by 10-15mm with your current springs would require you to have the circlips reset from the bottom to the middle position. This would also give you the option to go higher if need be in the future.
    Another option is to fit a pair of AJ120 6mm strut top spacers to give you an extra 12mm lift without the need to disassemble the struts and retain the same ride quality and suspension down travel.
    Peterpilot
    Leave a comment:
  • AJ120
  • AJ120
    replied
    And there you have it. Another punter with Heavy springs in the rear.
    Do you leave your airbags pumped up to the max all the time? Or only when your towing?
    the 250kg OME springs are the medium rated spring, they also do a 400kg constant load spring.
    I usually run minimal prssure in the air bags, 6-8 psi unless loaded for a trip and towing the camper, then around the 15-18psi mark. Just on a side note, i have mine connected to the one valve, so if there is a leak I wont get a lean as they will both deflate, also easier to pump them up that way
    Leave a comment:
  • mackayvx
  • mackayvx
    replied
    I have the 250kg OME rear springs with the poly airs, black widow drawers, fridge, tools, recovery gear, 100ah AGM battery in the rear, extra drawers on top of the black widows and it sits at around 830mm and rides nicely. I usually have the camper trailer swinging on the back as well.
    Leave a comment:
  • AJ120
  • AJ120
    replied
    Um put it this way Craig. Um. Um. Ill just leave it at that.
    Hey AJ.
    Ive got the blue Coil-rites from Air Bag Man.
    You know it could be a simple as a cracked line or leaky connection. Id better get the soapy water spray bottle out!
    But I know for sure that 250 + kgs in the back & roofracks etc is way too much for STD raised springs.
    I was hoping airbags would take the weight, but I would say that they would really be for leveling purposes only.
    Thanks for the idea. I will check the lines for airleaks but Im sure Id still be up for HD springs in the rear.
    Cheers.
    Leave a comment:
  • mackayvx
  • mackayvx
    replied
    Yup :-D bet Tanya is ecstatic?.........
    I am not sure what brand of airbag you have Drew but I think you might have just been unlucky. My airbags have done a bucket load of dirt and off road work including the Cape and they are standing up perfectly. In fact I reckon they are tough as nails.
    I have the Polyairs!
    Hey AJ.
    Cheers.
    Leave a comment:
  • mackayvx
  • mackayvx
    replied
    Well you know, it shouldn't start bouncing because of an air bag.
    Sit lop sided ok, but its the shocks that are supposed to dampen the bounce.
    It is possible your Billy's are shagged, the air bags may have been hiding the real problem?
    I'd be checking those billys out properly! Especially after the last set I saw on Anders vehicle.
    Yes thats a fair call ####. When I seen that post about them buggered struts I immediately inspected the struts and shocks for leaks and couldnt find any. Ill check again but ive seen leaking shocks before and mine are still clean. I think the springs are far too overloaded. Apart from leaks and split bush's, what else should I be looking for when inspecting struts and shocks?
    Leave a comment:
