Suspension Measurements 2
This is a sticky topic.
  • Re: Suspension Measurements 2
    Front - OME Spring/Nitrocharger Sport strut/Custom top plate spacer/Custom captive spacer/Sway Bar spacer/ToyTec diff drop/Light Racing upper control arms:
    830mm
    Rear - OME spring/Nitrocharger Sport Shock/Custom extended shock mounts/Custom spring spacer/Swaybar spacer/Extended bump stops;
    860mm
    Tyres are 265/70/17 Mickey T MTZ's.
    Mick
      MickL,
      Is that a 90mm lift achieved? :shock:
        Jesus Mick. Looks incredible. WOuld be great to see a picture of yours next to a standard lift and a stock standard to see the real differenmce in there.
        Are you happy with the ride quality or is it the same as with the standard lift prior to your playing around?
        [COLOR=#000080]Nick[/COLOR]
          A stocker (GXL) is around 750 front 780 rear. Mine was 745/765 when I started out; Dual battery in front and Outback drawers in the rear first time I measured.
          I had OME springs and shocks in it for the last 45k km's so ride is much the same except for the shock valving as I have upgraded to Sports Nitrochargers, these are a good improvement over the standard Nitrocharger valving. My Nitrochargers were a little tired to say the least so handling has improved by a good margin.
          Mick
            Hey Mick, what is your going rate?
            I reckon you might have a few folk on here wanting to acquire your expertise!
            You rig looks the ducks!
              I've been reading all the height measurements but I’m particularly interested in the droop measurements some people have posted.
              However I’m a bit confused as Double_D posted a RR/RL measurement of 850/855 and said only 20mm droop in the rear. Another post had a rear measurement of 860 and someone said there wouldn't be much down travel left in the shocks.
              What is confusing me is my rear is around 850mm and I have a lot more droop than 20mm. Perhaps I’m not understanding droop or how to measure it. I lifted a wheel off the ground on a track and measured from the bottom of the rim through the centre to the wheel arch and subtracted my normal flat ground value and got a figure around 125mm. Am I measuring wrong? What is a normal amount of droop at an average rear height of say 820?
              I have OME 896 springs with 60004 shocks. I will measure again and post exact measurements when I get a chance.
                I'd say that's a typo on Double_D's part.
                Mick
                  Well ive just put an ULTIMATE 50mm lift on the prado here are my measurements, after a 10km drive down a gravel road, I must say im very happy
                  RF735----770 LF737----770 RR767----817 LR770----822
                    I've had for the last 2 years and I've been rapt.
                    KONI shocks front and rear
                    KING springs front and rear
                    Poly Air Bags in rear
                    I now have issues with front suspension, rear is seriously good.
                    The set up was great until I did some more recent mods to the car. I've since added a winch and extra compressor/tank.
                    I've phoned the mob who supplied the original KING springs and they were rated for the lift and the bar work but not for the winch and other stuff.
                    I've noticed the front has dropped a bit since the last additions, so I'm about to change the front springs. Beef em up a bit.
                    My measurements now are;
                    FR 765
                    FL 750
                    RR 840
                    RL 830
                    I'd have to say the front has dropped a good 30 mil since adding the winch and other gear.
                    Sefo
                    ...........Heaps of cool stuff
                      Have just upgraded the original suspension after 92,500kms!
                      Used Shane at Suspension Stuff and had the following installed yesterday:
                      Dobinsons Coils F: (C59-302) R: (C59-327)
                      Lovells Gas Legend Shocks
                      Measurements:
                      Front Passenger 746 -> 773
                      Front Driver 743 -> 778
                      Rear Passenger 763 -> 831
                      Rear Driver 770 -> 839
                      Very happy with the onroad ride results so far. Will post about the performance following my trip to Fraser Island later this month.
                      2004 GXL 1KZ - ARB Deluxe Winch Bar - Safari Snorkel - Dobinsons/Ironman suspension - BFG AT 265/65/17 LT
                        Measurements:
                        When r u going to fraser??
                        [b]Rob[/b]
                          Old measurements ;
                          FR 765
                          FL 750
                          RR 840
                          RL 830
                          I just replaced the front springs, to OME heavy duty (enough to cope with all the weight I have)
                          Now back to 795 fronts!!!!
                            Catching the Manta Ray across on Monday 28th June.
                            4 blokes on a 40th birthday two week trip
                              We will be their the week prior, miss the school holidays!!!
                              [b]Rob[/b]
                                Iron man suspension fully loaded figures
                                Front with ARB bar and duel batteries 770mm
                                Rear vehicle fully loaded (2680kgs according to weigh bridge) home made shelving waeco 80l fully fueled and 120kg ball weight camper on the back 760mm
                                Normal measurements unloaded
                                Front 770
                                Rear 815
                                I was thinking going to a HD spring in the rear as i am now slighly nose up however i find the ride and especially articulation really good with the medium set up so i am not keen to muck around with it i may just get a new set of medium rear springs when i get back if she does not come back up
                                Dont list all ya mods, you will only be more upset when i get further
