Suspension Measurements 2
This is a sticky topic.
    Gldfishing
  • Gldfishing
    replied
    I had an ARB Sahara Bar fitted just before Xmas. Forgot to take measurements before fitting, so only have after measurements. These were taken with only 1/2 tank of fuel (45L). Took measurements twice at different spots to get average. Ground wasn't exactly level.
    FR 740/745 AV 742.5
    FL 747/740 AV 743.5
    RR 765/775 AV 770
    RL 775/765 AV 770
    Difference = 27mm
    Side steps level at 310mm
    The new bar doesn't seems to have dropped nose at all. It seems to have only tightened up the front so it feels less bouncy but that really just a guess. Vehicle feels good when towing the boat and boot full of tools. Will see how it settles over next few months before deciding to do. May just change struts/shocks and leave springs.
    Leave a comment:
  • Ourprado120
    Lurker
  • Ourprado120
    replied
    Just had Tough Dog 2" lift installed last week (near full tanks) Alloy bar twin batt
    LF 730 before to 800 after
    LR 730 before to 810 after
    RL 755 before to 815 after
    RR 755 before to 820 after
    Ride is good, old suspension was really buggered. Very happy
    Leave a comment:
  • t_witches
    Lurker
  • t_witches
    replied
    OME install on 120.
    Front:
    Shockers: 90000
    Coils: 2884
    Rear:
    Shockers: 60004
    Coils:2896
    Ride Height Measurements (Rim to Guard) mm
    Before: After: Difference:
    Front Left Hand Side: 735 795 60
    Front Right Hand Side: 735 800 65
    Rear Left Hand Side: 765 835 70
    Rear Right Hand Size: 770 845 75
    Fully Fuelled (180L), Empty cargo area, ARB Deluxe Winch Bar No Winch.
    Leave a comment:
  • blkd4d
  • blkd4d
    replied
    Originally posted by PradoGXL08 View Post
    Hi All,
    Just have fitted some OME's to My 120.
    Here are the details:
    Front:
    Shockers: 90000
    Coils: 2884
    Camber / Height:
    389 LHS
    390 RHS
    Rear:
    Shockers: 60004
    Coils:2896
    Camber / Height
    389 LHs
    389RHS
    Front Left Hand Side: 740 785 45
    Front Right Hand Side: 746 785 39
    Rear Left Hand Side: 745 812 67
    Rear Right Hand Size: 745 806 61
    My Prado was Fully Fuelled (250L) as I have a Custom 160L + STD Tank, with Custom False Floor with MSA Drop Down Fridge Slide and a Engel 40L Fridge Fitted, Codan HF Radio
    Also on front End - ARB Deluxe Winch Bar No Winch, 2 Batteries, Driving + Fog Lights.
    Tyres are 265/70/R17 Cooper AT3's, Near New only 12,000kms on them.
    Stuart
    That's better than standard Stuart . .
    blkd4d
    Leave a comment:
  • PradoGXL08
  • PradoGXL08
    replied
    Hi All,
    Front:
    Shockers: 90000
    Coils: 2884
    Camber / Height:
    389 LHS
    390 RHS
    Rear:
    Shockers: 60004
    Coils:2896
    Camber / Height
    389 LHs
    389RHS
    Stuart
    Leave a comment:
  • Hutch
    Addicted PP Member
  • Hutch
    replied
    You got some sag in your rear end buddy...
    Leave a comment:
  • matt150
  • matt150
    replied
    Just picked up some very low kilometer second hand OME 896 rear coils to try out in the 150. The drawers and fridge have given me abit of weight to carry around. I'm planning to try some different set ups for the rear end with regards to the weight of my camper and stuff to see what suits me best.
    Leave a comment:
  • pjorek
  • pjorek
    replied
    Originally posted by Flea LeCrowds View Post
    Hi pjorek, Are you happy with the OME lift and performance? I have mine booked in for Thursday so am interested to hear from anyone who has had the work done recently.
    I'm still happy with mine. I went 2895 at the back and really both 2896 and 2895 are good depending what you're after. I must say ARB after sale has been really good. They rang me a couple of times make sure all is well etc
    Leave a comment:
  • Smithy - 120 D4D
  • Smithy - 120 D4D
    replied
    Hi Flea, I had OME installed into mine a week or so back. 2884 springs with 90000 sport struts in front, and 2896 springs and 60004 sport shockies in the rear.
    Measurements as follows:
    Before - LF 730, RF 740, LR 765, RR 770
    After - LF790, RF 790, LR 830, RR 835
    Definately a firmer ride, but feels heaps more stable. Before and after shots on my rig build also. Haven't had a proper chance to test it all out yet, but am sure it will be up to the challenge!
    Leave a comment:
  • Flea LeCrowds
    Lurker
  • Flea LeCrowds
    replied
    Leave a comment:
  • Peterpilot
  • Peterpilot
    replied
    Originally posted by pjorek View Post
    So getting 70 to 80 droop. Seems interesting that new OME shocks give you similar drop to standard shocks, which means height was gained for reduced shock travel. Are most here getting 880s and 890s drop at the back?
    I was getting 880mm full extension at the rear and 845mm at the front with standard shocks. With similar length rear shocks to AJs and some sway bar spacers, I got 930mm at max extension. Read post #230 in this thread for details. At the front, I ended up with a max extension of around 890mm with longer struts, I also have a diff drop kit from AMTS to reduce CV angles at max droop.
    Leave a comment:
  • pjorek
  • pjorek
    replied
    Makes sense both Andrews, thanks!
    Leave a comment:
  • Guest
    Guest
  • Guest
    Guest replied
    If you look in the Suspension Database thread, the OME shocks are only 5mm longer than factory.
    http://www.pradopoint.com/showthread...nsion-Database
    And AJ120's LC80 shocks are 45mm longer.
    Leave a comment:
  • AJ120
    Out of control poster!
  • AJ120
    replied
    Thats around what I was getting with the OME Prado shock, I changed to 80 series rear shocks (OME N71E) and extended the rear sway bar links and now get 930mm. Pretty happy with that result, full details in my build thread.
    Leave a comment:
  • pjorek
  • pjorek
    replied
    Leave a comment:
