G'day,
Well its time for my rig to get her 2" suspension lift and I would like peoples opinions on the below setups. My rig will have the following constant weight of bullbar+winch, dual battery's, under carriage bash plates, rock sliders, roof rack, dual wheel carrier rear bar, draw system with large recovery bag and tools, 50l fridge. When camping it will also carry a rooftop tent, 50l drinking water and a variety of tables, chairs, gas cookers etc for camping and up to 3 passengers. Its not intended as a tow vehicle but will have a 3.5m dingy on the back from time to time. The vehicle is being built to tour the Kimberley eg. Gibb River Rd and I also plan to take it through the middle and up to the Cape.
This is the OME setup quote:
"4 x Nitrocharger sport shock absorbers, 100kg-150kg front coils and 150kg-400kg rear coils using poly air bags to help carry the extra load. This complete package including air bags will cost $2125 fitted or without air bags $1700 (fitting the airbags at a later date would cost $525)". Pirce comes with stone guards but no wheel alignment as they recommend getting one done after 500k's once everything settles in.
And here is the Koni/ Lovells Springs setup:
"Koni HT Raid shock absorbers front and rear with the Lovells springs. The Konis are thicker bodied, rebound adjustable, rebuildable, hydraulic units which are made specifically for heavy weight applications doing lots of four wheel driving. They are made stronger then other shock absorbers with up-rated seals and all the rest of it to last longer while working harder. The Koni/Lovells kit will cost $2,490 supplied, fitted and wheel aligned.
We can also supply and fit Polyair helper airbags that sit inside the rear coils to assist with extra weight carrying and occasional towing. These aren’t necessary but do help and would cost an extra $500 on top of the kit."
I plan to fit my bullbar, rack, rear bar etc around the 20th and will be keen to pull the trigger on the lift asap. Im leaning towards the OME setup due to the warranty coverage.
Thanks in advance,
Thanks in advance,
ondaboat
