1kz te grande suspension lift is this possible
This topic is closed.
  • 1kz te grande suspension lift is this possible
    Hey wanting to get a 2inch liftkit on my grande is this possible with the rear airbags still functioning and where in melb can I get this done I was quoted to get bill steins and dobinsons but not sure if ill get the lift can someone pl help
    The short answer is yes!
    The longer answer is its been discussed a lot before, so here is what you need to do to find all the good oil.
    Click on your settings tab (top right) then on the next page find general settings (left middle) then scroll down and find the default thread cut off age and select from the beggining, then go to the bottom of the page and save settings. This will give you access to all previous threads.
    After that go to the 120 suspension section and use the search this forum function on the right of the header tab, go advanced, select thread titles only and type in Grande. This will bring up loads of info for you, should keep you reading for a few hours and you will learn a lot.
