Ironman 50mm lift car seems to wallow side to side ???
  • Ironman 50mm lift car seems to wallow side to side ???
    Hi guys, I did a suspension lift a few months ago with the ironman 50mm kit, while I am happy with it generally I still it feels wallowy (I dont know how else to describe it) side to side when driven on the highway, small hand movement on the steering wheel transform into a side to side movement of the car. I didnt extend to rear sway bar and was considering giving that a try, its had a wheel alignment, but I thought I would ask if anyone else has had the same symptoms.
    cheers.
    I have a similar situation since I replaced my old lift with a new one. Still trying to work it out.
    Michael and Kelly
      Sure that the swaybars are bolted back on? Otherwise the shocks are too underdamped
        Positive everthing is bolted back up?????
        Shocks are new as come with the kit, Ironman front strut 12710GR Nitro gas and 12682GRC Nitro Gas rear shock.
        With all the reading I have done on this forum this installation has been done heaps, Maybe its just me,
          I believe there is a foam cell shock which is firmer.
          Perhaps you can test drive a similar setup just to compare.
            did give that a thought, a lot of Prados up here, will put the word around to see who has a similar setup.
              Hi Brett
              Where abouts are you up here, Im in Paraburdoo. I have TJM XGS Gold very happy with it.
              2008 Prado GXL D4D Auto Silver, 265/70x17 Mickythompson ATZ 4 ribs, ARB delux Bar Avenger Mako 9500 winch, TJM XGS Gold suspension, Poly airs, Safari Snorkel, Dual Battery system, Voltage Booster, Lightforce XGT lights, GME TX3100 UHF,ARB CKMA12 Compressor, ENZD special quad breather kit,Outback Draw system 1/2 Cargo Barrier,Kaymar duel wheel carrier,AJ120 Sliders, Taipan XP Exhaust, Twin E Lockers, Foxwing, Pioneer Platform.
                Originally posted by wsp View Post
                Hi Brett
                Yes WSP I am in T.P. will touch base if I cant find anyone over here with a similar setup.
