I was wondering if you can put in strut spacers and coil spacers plus a lift?
They only provide an extra 15mm of lift.
As AJ said, Strut spacers yes no worries.
Coil spacers on the other hand on the rear will only push the shock more open towards it's topped out length.
People usually run the front Strut spacers on the Prado's to level them up a bit.
Doing that in the front, then running coil spacers in the rear too wil put the rake back in it.
I don't like spacers, but if your going to use them, you should extend your bump stops.
you cannot compress a spacer & it can cause damage, but then you might be lucky.
