http://www.pradopoint.com/showthread...ension-install follow that link but scroll down the page a bit, Chippy did a pretty good write up with plenty of pictures so scroll through the first few pages and you will suss it out.
I'm also thinking about a lift in the next few months, looking at billies and probably dobinsons or kings, Ive got a lot of weight up front and at least 100KG+ in the back, I know the B6 shocks are all the same but what springs have people with similar weight gone for, I see 40mm and 50mm ??
I went ironman foam cells in my 120kzj... Brilliant and plush... Just leave the spacers that come with the kit out....unless you run steel bullbar and winch... It sits too high with them in.
Black mica 06 D4D GXL. , kitted out to take me where we need to go to feel free......
I went OME a couple of months ago. Very happy with the ride. So much better than the 10 year old factory suspension.
Their website has a good selector on it but no prices. You need to ring ARB for that.
Went for a bash in the dunes on the weekend and noticed a bit of a thump coming from the rear occasionally when climbing hills, I'm guessing it was hitting the bump stops and not anything actually wrong. Cross fingers.
Blake
great thread! I'll be studying this for mine when I do it, when you mention: 10: Loosen the cam bolts on the LCA, they are not the ones pictured are they.. this point is where I get lost :?
No I'll post another photo when I get the mud off. The cam bolt is the part that gets adjusted during alignment. It is where the LCA meets the chassis.
thanks I'll email with another question, you need to start charging!
Spacers means that you will need to space down the bumpstops as well. The 6mm ones AJ120 does will be fine as that is a minor spacer more to correct a bit of sag.
Give the guys above a call to discuss your options.....
Kim
Just had my 120 done by Arnie with bilsteins and lovelles springs 2" lift
All I can say is the guys a geniues, my Prado is so much nicer now, does every bit, alignment and camber adjustments spot on
Drives and handles fantastic, feels more sure footed on the road
[SIZE=5][I]You take the highway..I'll take the by way[/I][/SIZE]
