Originally posted by amts
View Post
Wanting to do a 2inch Lift
Is AJ120 selling them, anyone have the link?120 GXL, D4D Auto 2007 - ARB Deluxe Bar, Warn Tabor 10K and Rec Kit, Safari Snorkel, GME UHF, BFG AT's, Lightforce Spots, Eclipse Sat Nav, Waeco CF40, Optima D27, Redarc Sbi12, Leigh W Diode, Voltmeters, Rhino Pioneer platform, ARB compressor, DIY Trek Table & drawers, HiLux Jets, Breathers, Water pump, rear custom fused electrical system, camp lights, LED's, ARB Roof top tent Annex and Awning, Maxtrax, Hi-Lift, Shovel. [URL="http://www.pradopoint.com/showthread.php?27929-DJ-D-s-D4D-120-GXL"]My Build Thread[/URL]
In the long run you may as well just get yourself some bilsteins and kings or dobinsons springs to suit. I cant recall anyone ever being unhappy with the setup . (maybe there was one though very rare I think).Originally posted by [email protected] View PostWhat is the go with spacers? is that something people are doing or is it just a bit of a waste?
If you go with the Bilstein 5100's you get adjustable spring platforms so you can run adjust the height to suit your accessories.
You can import your on Billies from downsouthmotorsport.com in the states. Mine were around the $500 delivered when the aus was 1.062009 120 V6 Auto. 265/70/17 Goodyear Silent Armours. Bilsteins and Kings Springs.
Thanks for the info, I was looking on ebays US at the 5100's nearly fell over when I saw the price difference.. Was that $500 for 4 or 2? I think I'll go for them (OS) and some dobinsons locally. cheersOriginally posted by tassie tiger View PostIn the long run you may as well just get yourself some bilsteins and kings or dobinsons springs to suit. I cant recall anyone ever being unhappy with the setup . (maybe there was one though very rare I think).
You can import your on Billies from downsouthmotorsport.com in the states. Mine were around the $500 delivered when the aus was 1.06120 GXL, D4D Auto 2007 - ARB Deluxe Bar, Warn Tabor 10K and Rec Kit, Safari Snorkel, GME UHF, BFG AT's, Lightforce Spots, Eclipse Sat Nav, Waeco CF40, Optima D27, Redarc Sbi12, Leigh W Diode, Voltmeters, Rhino Pioneer platform, ARB compressor, DIY Trek Table & drawers, HiLux Jets, Breathers, Water pump, rear custom fused electrical system, camp lights, LED's, ARB Roof top tent Annex and Awning, Maxtrax, Hi-Lift, Shovel. [URL="http://www.pradopoint.com/showthread.php?27929-DJ-D-s-D4D-120-GXL"]My Build Thread[/URL]
Yes I am selling them, Link is here http://www.pradopoint.com/showthread...-Strut-spacersOriginally posted by [email protected] View PostIs AJ120 selling them, anyone have the link?
Haven't sold any for months and months and then a bit of a rush on them the last 2 weeks, only one set left in stock at the moment.
You can do it without loosening the cam bolt - I replaced the passenger side Bilstein on my 120 series while sitting in the dirt of the Birdsville caravan park two weeks ago.Originally posted by [email protected] View Postgreat thread! I'll be studying this for mine when I do it, when you mention: 10: Loosen the cam bolts on the LCA, they are not the ones pictured are they.. this point is where I get lost :?
The shock failed in such a way that the shock body separated (totally!) at the circlip retention ring. It failed on the sand dune immediately prior to Big Red, but I was able to drive over Big Red and into Birdsville. I was not hammering over the dunes prior to the failure, so I do not know the cause of the shock dying.
I strongly recommend packing a hydraulic jack in addition to the standard Prado wind up item, because the two jacks made the job safer and much easier.
My absolute top tip is to pack one of the 12 volt rattle guns. A mate gave me one as a present - I never would have bothered with it otherwise - but having tried one I now say that they are one of the best tools you can pack, and are well worth the weight penalty.
If you have Bilsteins, then I also suggest getting a hex key that fits the top shaft of the shocky - to stop the shaft turning while you tighten the top retaining bolt - and cutting the short leg REALLY short - about 5 to 8 mm max. Without the hex key there is no easy way of holding the shaft while you tighten the top nut, and I could not have got an unmodified hex key into the space between the top of the shock and the underside of the wheel arch.
YMMV, Tony
Kind of. You can have them re-valved here if you like. They are the same part numbers as you buy here and I am 99% positive that Bilstein Australia dont revalve them when they get here though happy to be corrected if there is evidence they do.Originally posted by craigm View PostJust be aware that the US shocks aren't valved to suit the tougher Australian conditions...
What I can say is that the ones I imported from the states are simply superb on mine. Keep in mind though that coming from an off road racing background there is nothing on my 120 that doesn't need to be there so its probably one of the lightest getting around. Add bar work/rear shelves/rear carrier and they may well struggle.
I thought there were a couple of others who have imported them and would be interested in their observations.
cheers2009 120 V6 Auto. 265/70/17 Goodyear Silent Armours. Bilsteins and Kings Springs.
Interesting, Im glad you mentioned it. Im curious tho what would re-valving do for Aussie conditions? create a faster compression/recover rate? Im in the mountains so 90% of my driving will be steep accents/descents and rocky terrain..
Originally posted by tassie tiger View PostKind of. You can have them re-valved here if you like. They are the same part numbers as you buy here and I am 99% positive that Bilstein Australia dont revalve them when they get here though happy to be corrected if there is evidence they do.
cheers120 GXL, D4D Auto 2007 - ARB Deluxe Bar, Warn Tabor 10K and Rec Kit, Safari Snorkel, GME UHF, BFG AT's, Lightforce Spots, Eclipse Sat Nav, Waeco CF40, Optima D27, Redarc Sbi12, Leigh W Diode, Voltmeters, Rhino Pioneer platform, ARB compressor, DIY Trek Table & drawers, HiLux Jets, Breathers, Water pump, rear custom fused electrical system, camp lights, LED's, ARB Roof top tent Annex and Awning, Maxtrax, Hi-Lift, Shovel. [URL="http://www.pradopoint.com/showthread.php?27929-DJ-D-s-D4D-120-GXL"]My Build Thread[/URL]
I am sure Dave from Autocraft in Melbourne revalvs them. (or did)
Mine have done everything other than corrugations. At xmas we did McIntyres and the other place on the Goodradigbee when it was 44 degrees. Fully loaded with camping gear and they were superb.
Twas so hot the 1kz was getting hot!2009 120 V6 Auto. 265/70/17 Goodyear Silent Armours. Bilsteins and Kings Springs.
amts is running the 5100 & 5160's which he is very happy with. I contacted Sonny at Downsouth last year as recommended by Andrew and queried Sonny re the valve rates. He mentioned for general touring and day to day driving they would be fine, however made no guarantees on how they would perform on a fully laden vehicle across harsh terrain (corrugations etc...)2004 V6 Grande. BLACK -
Great tracks! I know the feeling, going up or down gentle Annie can be tricky in the heat.Originally posted by tassie tiger View PostI am sure Dave from Autocraft in Melbourne revalvs them. (or did)
I think for the money I'd take the risk, It would be a while before I do any serious outback trips and there is a lot of NSW and VIC I want to do first.120 GXL, D4D Auto 2007 - ARB Deluxe Bar, Warn Tabor 10K and Rec Kit, Safari Snorkel, GME UHF, BFG AT's, Lightforce Spots, Eclipse Sat Nav, Waeco CF40, Optima D27, Redarc Sbi12, Leigh W Diode, Voltmeters, Rhino Pioneer platform, ARB compressor, DIY Trek Table & drawers, HiLux Jets, Breathers, Water pump, rear custom fused electrical system, camp lights, LED's, ARB Roof top tent Annex and Awning, Maxtrax, Hi-Lift, Shovel. [URL="http://www.pradopoint.com/showthread.php?27929-DJ-D-s-D4D-120-GXL"]My Build Thread[/URL]
I have been chatting to Andrew about his, what are you running Craig B6's? how have they lasted for you?Originally posted by craigm View Postamts is running the 5100 & 5160's which he is very happy with. I contacted Sonny at Downsouth last year as recommended by Andrew and queried Sonny re the valve rates. He mentioned for general touring and day to day driving they would be fine, however made no guarantees on how they would perform on a fully laden vehicle across harsh terrain (corrugations etc...)120 GXL, D4D Auto 2007 - ARB Deluxe Bar, Warn Tabor 10K and Rec Kit, Safari Snorkel, GME UHF, BFG AT's, Lightforce Spots, Eclipse Sat Nav, Waeco CF40, Optima D27, Redarc Sbi12, Leigh W Diode, Voltmeters, Rhino Pioneer platform, ARB compressor, DIY Trek Table & drawers, HiLux Jets, Breathers, Water pump, rear custom fused electrical system, camp lights, LED's, ARB Roof top tent Annex and Awning, Maxtrax, Hi-Lift, Shovel. [URL="http://www.pradopoint.com/showthread.php?27929-DJ-D-s-D4D-120-GXL"]My Build Thread[/URL]
Corrugations really are the true test for a shock, Slow steep or rutted driving isn't going to stress a shock much, load it up and head over corrugations and you sort out the men from the boys as it were.Originally posted by tassie tiger View PostMine have done everything other than corrugations.
Still running on the BE5- A712's & BE5-A713's which apart from some blown out bushes on the front due to a mechanic tightening up the bolts whilst it was on the hoist, they've been good. Just after some longer travel like Andrew's 5160's etc. Caloffroad have got a pretty good solution I understand, so I may look to them next. I cant go any higher (Prado only just fits in the garage now), but am craving more articulation and a longer shock may assist...Originally posted by [email protected] View PostI have been chatting to Andrew about his, what are you running Craig B6's? how have they lasted for you?2004 V6 Grande. BLACK -
