Bilstein 5100 Shocks - FJ Cruiser & Prado 120
  • Bilstein 5100 Shocks - FJ Cruiser & Prado 120
    Good day everyone,
    I'm looking at a Bilstein 5100 suspension for my PRado, but would like to know if the shocks from a 2012 FJ Cruiser would be compatible?
    The shocks I'm looking at are:
    Front: model 24-196499 (collapsed 17.57'', Extended 22.48'') - series 5100, adjustable
    Rear: model 33-187174 (collapsed 14.91'', Extended 23.50'') - series 5100
    I've come across a catalog online and it seems the rear shocks will fit, as they will fit the FJ Cruiser year '06 up to '12. I believe then it will be compatible with the Prado 120 GXL also??
    If anyone has more info on these it will be greatly appreciated..!
    Henno
    I have just ordered a set from Downsouth motorsports and after a good deal of research the models I ordered are:
    Bilstein 5100 Series Shocks
    05+Toyota Tacoma '07-09 FJ Cruiser & '03-09 4-Runner Front 5100 Pre-Load
    Adjustable Shocks
    *-TA-BE5-C475-H1/24-186711
    2 90.00 180.00T
    Bilstein 5100 Series Rear Shocks for
    Rear Toyota FJ with 0" to 2.0" Lift
    and '03-'14 4-Runner
    *-TA-BE5-E703-H0/33-187174
    you might want to check the front part number, also amts has installed these on the front of his, so maybe check his build.
    Also check the suspension database thread
      For the front struts, the 24-186711 has a shorter collapsed length which is closer to the factory shocks. This is better so that you don't bottom out on the shock but on the bumpstops.
      Here's the Suspension Database thread http://www.pradopoint.com/showthread...nsion-Database
        Cool thanks - the catalog I found also indicated the front shocks model 24-186711 you have above. The collapsed and extended lengths differ slightly, so I guess the newer FJ uses a slightly different shock:
        24-186711 - COL: 17.03, EXT:22.56 ('07 - '09 FJ)
        24-196499 - COL: 17.57, EXT:22.48 ('10 on FJ)
        Our Prado's seem to be in the older FJ's grouping...
        Will check with amts thanks
          Yes that's right. Stick with the 24-186711.
            Great, thanks amts - so you are saying the 24-196499 will fit but not ideal due to the shock bottom out? IS there a way to adjust the bumpstop position or spacer it so that bottom out occurs on the stop?
              On a slightly different note - I have an ARB bar fitted (deluxe bar - heavy winch compatible one, but no winch)...would the 24-186711's still be tho ones to go for and would I need to look at replacing the stock coils when doing the shock upgrade?
                I think amts is saying if you use the smaller shock it will run out of length before you reach the bump-stops, it sounds to me like you could move the bump-stop or enlarge it but you would be essentially shortening your articulation. a bit counter productive in a "lift" situation. correct me if im wrong
                  Yea I suppose - I could get a set of the shorter ones new off-hand for cheap, but like you say counter productive so probably not the way to go...!
                  Thanks guys
                    Yes, what dj said.
                    The shocks don't carry weight, the coils do. So you might want to consider changing the front coils due to the bullbar. What are the front and rear suspension heights now? Measure from bottom of rim to top of wheel arch through the center of the rim/hub.
                      I did the measurements and just didn't get around to posting them here...this is what they are:
                      FL: 740mm
                      FR: 735mm
                      RL: 765mm
                      RR: 765mm
                      From the suspension measurements thread, it seems the 740mm is pretty much in line with what can be expected, 735 may be sagging there just a bit..?
                      Henno
                        FL: 740mm
                        FR: 735mm
                        RL: 765mm
                        RR: 765mm
                        Henno
                        Your front to rear height difference (i.e. rake) looks ideal. Are you after a lift or staying at standard height?
                          Great, thanks! I'm probably going to stay at standard, for the time being anyway...
