Strut travel and lower control arm bump stop separation on Prado 120 IFS
  • Strut travel and lower control arm bump stop separation on Prado 120 IFS
    Hey everyone,
    After reading of the problems that some FJ cruisers were having with after-market bump stops and extended travel struts with longer closed lengths, I thought it would be a good idea to see what the relationship is between strut travel and lower control arm-bump stop separation for the Prado 120.
    Problems with FJ Cruiser and after market bump stops;
    http://www.fjcc.com.au/f36/superbump...-details-1413/
    I spent an afternoon, and pulled the coil out of one of my 712 struts and put the strut by itself back in. This way there’s no coil bind holding anything up, and I can freely measure all the way to the bump stop.
    This is the relationship I measured;
    As you can see from the graph, the ratio between strut travel and control arm-bump stop separation is 1.5:1. This is a substantial difference to the 2:1 assumption in the FJ thread. Note that I did not use the shroud for these measurements, this is from washer seat to ring-eye centre.
    As discussed in the FJ thread, the after market bump stop was far too soft, and compressed so far that the struts bumped out, and actually forced the shock body into the shroud. This suggests the internal strut bump stop has failed also.
    The Prado 120 and FJ Cruiser IFS geometry are very similar (identical?) as far as I can see from various discussions.
    If you were to use a typical 433mm closed length extended travel bilstein, and then you also put a shroud on it, then both the closed and open lengths are shifted. On the top of the shroud there is a small metal cylinder which slips over the strut shaft. This cylinder is 7.8mm high (call it 8mm).
    So by using the shroud, the strut is physically lowered by 8mm from the bottom of the washer, giving a new ‘effective’ closed length of 433+8 = 441mm.
    The after-market bump stops used in the FJ thread compressed much more easily than the OEM bump stop, up to 25mm (possibly more). If you follow the extrapolation in the plot, you will see -25mm compression is at a strut length of 440mm, which is when the long travel strut (with shroud) will have bumped out in the FJ.
    You can see for my Prado 120, I could get the OEM bump stop to compress by around -6mm with the jack under the control arm supporting the weight of the car.
    So from these figures, I initially thought it was safe to use long travel bilsteins with closed length 433mm, and as far as I know, nobody has reported any bump-out issues with 5100’s so far?
    Something else of note is that the FJ must have had solid coil bind, or very close to it. I also left the coil seat on my strut when I did the measurements without the coil, so I could measure the approximate coil working height. This is what the plot looks like;
    For my ZC7296, I calculate a solid coil length of around 207mm.
    The FJ user didn’t specify what coil lengths or coil type he was using, but even so, the coils must have been very close to full solid bind.
    It must have been quite a hard hit to do this. We’re talking 3 times the normal corner car weight in Force to bind a coil solid at -25mm bump stop compression.
    So after pulling out my 712 strut, I carefully measured closed-open lengths, and I can see that the open length is 553mm, spot on the quoted figure for a 712 strut, but my closed length has decreased by 5mm, and the shaft flange where the washer sits can now actually travel inside the shock body.
    Not good!
    If you add the shroud length of 8mm, my effective closed length should have been 427+8=435mm when the 712 strut was new. This shows that during my travels, it’s likely that repeated bump outs have destroyed the internal bump stop in my 712 strut. I can also see where the paint has rubbed off on the control arm from bump outs.
    I’m guessing there must have been some flex in the lower strut bush and the top hat rubber for this to happen, and my lower strut bush is definitely off centre now. Other possible contributing factors to consider are the ageing of the bump stop rubber, and the softer valving in bilsteins, a common complaint across all types of 4wd’s.
    So the moral of this story is that if a 712 strut with effective closed length of 427+8 = 435mm can get bumped out on an OEM bump stop and destroy the internal strut bump stop, then you can also bump-out a longer 433+8 = 441mm closed effective length on an extended travel bilstein. The longer closed length on an extended travel bilstein means it will always bump out before a 712 strut does.
    Even though it is stated in the FJ thread that FJ’s with OEM bump stops and the same extended travel bilstein struts had no problems, I think a 5mm spacer (protecting 5x1.5 = 7.5mm strut bump travel = shroud cylinder height) on the OEM bump stop is a good idea for long travel bilsteins with closed length 433mm, particularly if you use the shroud. Over time, repeated bump outs may destroy the internal strut bump stop.
    Maybe in the new extended travel monotube Bilsteins the internal bump stop is better engineered. Without actually eyeballing one I can’t say. The 712 strut is a very old design (I quote 30 years from a seller), and I’m suspicious the new Bilstein/TRD monotube is just a longer version of the 712. If anyone has some engineering knowledge I’d like to hear it!
    This is also the reason why I very much lean towards a minimum closed length of 420mm (even less), which is what the OEM Prado 120 strut is. You would typically always get solid coil bind before you bump out 420mm closed length, so even if the bump stop completely failed, your strut will hopefully survive.
    So putting Hilux struts with long closed length around 433mm into the Prado 120 or FJ is in my head not as straightforward as it seems.
    If anyone has had some experience in this area I’d like to hear your thoughts. Hope this is informative to those with long closed length extended travel struts. Watch out for the big bumps!
    Best
    Mark
    After reading the information posted in this thread ( http://www.fjcc.com.au/f36/superbump...-details-1413/ ) it would seem that the "problem fixer" SuperBumps from Wheelers are not the bottoming-out messiah that they are advertised as being.
    I have bought a set of these and just want to know your opinions on them given the fact that these guys had failures after travelling at excessive speed (100-120) on dirt roads and after hitting a few bumps bigger than expected.
    For someone whose car is mostly on the road and when it is 4WDing is slow track stuff where uptravel is desirable or beach running stuff (max speed of 70km/h if that) are these "progressive" bump stops going to be that detrimental to other components of my vehicle? (2" lift - billies and lovell springs - with strut spacer and 33" tyres).
    Interested to hear your thoughts on whether or not I should invest in another product e.g. Timbrens or simply add a spacer to the OEM bump stops, although, I was a fan of taking the harshness of the bumpstops out of the equation with the SuperBumps from Wheelers.
      Hey rorza,
      I did read on the FJ forum that the quick fix for the SuperBumps was to add a spacer.
      My foremost thought with the bumpstops is to not mess with the OEM geometry.
      What Bilstein struts are you running, closed-open lengths?
      I make sure I run struts that are 420mm closed length with OEM bumpstops, as this closed length includes the 'bumpstop failure' safety margin that Toyota built into the original geometry. OEM struts are 420mm closed length.
      I'm not fussed by big hits on my bumpstops, I prefer to drive to conditions and try to slow down for big bumps that I can see coming, but if I hit one hard and it feels bad, then I'm not worried, that's what the bumpstops are there for.
      You should also read my explanation of this in post #25 of this thread;
      http://www.pradopoint.com/showthread...e-dust!!/page2
      If your Bilsteins are 712's, then your closed length should be around 427+8 (shroud) = 435mm. Long travel Bilsteins are 433+8 = 441mm closed.
      This is too long for me, although plenty of folks run them on 120's.
      If you're concerned about safety margins (which can obviously disappear quickly with SuperBumps), and you want to continue with the SuperBumps, I would definitely space them down.
      Also, how thick is your strut spacer? This also lowers the strut and effectively increases the closed length.
      Best
      Mark
      Whitey
      Shockie Maker of the Month Award
        My Bilsteins have the number F4-BE5-A712-M2 TYP2/- on them so I'm guessing these are the 712's you speak of.
        I have a 20mm strut spacer in the front. The super bumps did come with spacers (a 6mm and a 10mm which can be combined).
        I'm concerned about the safety of the suspension components, definitely, and want to run appropriate equipment to ensure it's longevity offroad which is why I value your opinion. I do realise running strut spacers is not optimal for geometry, also.
          Hey again rorza,
          When you say 20mm strut spacer, do you mean i) a spacer that gives you 20mm of lift, or ii) do you mean a spacer that is actually 20mm thick?
          Case i) would mean a spacer that is 20/2.2 = 9.1mm (prolly sold as a 10mm spacer), and case ii) is 20mm.
          I'm guessing it must be a coil spacer as well, as the maximum strut spacer you can fit is about 6mm before you need to change the strut cap studs to a longer length.
          Either case is too much thickness, you will eventually break something, have a quick read of this thread;
          http://www.pradopoint.com/showthread...t-plus-spacers
          At a minimum of case i), your closed length will be 427+8 (shroud)+9 (spacer) = 444mm closed length.
          At this closed length, you will definitely bump out your 712 strut if you are running the SuperBumps without a spacer.
          I'm sure you appreciate the hazards of running spacers, but I would strongly suggest you get your lift with the correct choice of coils rather than spacers.
          The coil spacer will also reduce your droop on the IFS by a 1:1 ratio, so if you use a 10mm spacer, you lose 10mm of droop, no good! I don't run spacers anywhere in my Prado, as I want the maximum articulation I can get!
          What is your current ride height front and rear, and what coils are you using??
          Best
          Mark
            My apologies, it is a coil spacer NOT strut spacer. It was sold to me as a 20mm spacer and to my understanding that is referring to the lift gained from installing it.
            In terms of coils all I know is that they are Lovells HD and are part of a 2" lift kit that I purchased from a workshop. Unfortunately, I have no record of exactly what they are. Are you aware of any springs that will provide 3" lift so that I can eliminate the need for the coil spacers?
            My measurements from bottom of rim to wheel arch is ~810mm front and ~840 rear
              rorza,
              What is your droop? The A712 isn't a long travel strut so going for a 3" lift, the strut may run out of droop.
                Hey rorza,
                Amts is spot on, have a look here at how your strut open length affects your droop;
                http://www.pradopoint.com/showthread...-Prado-120-IFS
                Keep in mind your current droop will be different to this plot because of your spacer.
                While a 3" lift is technically illegal everywhere in Australia with the new ADR (50mm lift maximum from tyres+suspension), the coils that will give you the lift you are after without spacers;
                Front C59-314
                Rear C59-443V (variable spring rate coil 470mm free height), or the new C59-487 (linear spring rate 430mm 280lb/in)
                The C59-487 is more for a heavily loaded rear end. I just got this coil designed by Dobinsons over Christmas, so it isn't listed in the suspension database yet.
                Look at the 120 suspension database here;
                http://www.pradopoint.com/showthread...nsion-Database
                I would not run 512 struts at 3" lift, you will have less than 30mm droop and you will top-out and kill your struts.
                If you want to run a 3" lift without spacers and coils only, you need a 570mm open length strut, and you will need to replace your upper control arms to get the wheel alignment back in spec, put in a diff drop etc etc.
                Similarly for the rear, there's no point running a 3" lift without long travel shocks. Look at 80 series shocks. You'll also need longer brake lines, extended swaybar links, tailshaft spacer etc etc.
                Read post #4 here for a more detailed list of what to do for a 3" lift;
                http://www.pradopoint.com/showthread...lift-questions
                Best
                Mark
