Hey all,
After performing full articulation measurements on the lower trailing arm-axle housing separation on the rear of the 120....
http://www.pradopoint.com/showthread...n-on-Prado-120
....I had to perform some parallel measurements to find the true trailing arm binding limits on the rear end.
This is because in parallel everything binds at shorter shock open lengths compared to when the axle housing is fully articulated.
Here are my new measurements;
With a horizontal axle, the lower trailing arm will bind at approximately 700mm shock open length. Fully articulated it won't bind until around 800mm.
This shows that if you are not running a swaybar then you can run rear shocks out to an open length of 700mm before binding occurs.
The offset lower trailing arms from Superior really then only become necessary in two possible cases; i) for those running without swaybars and running shocks with open length longer than 700mm, which is not very many folks, and ii) to allow longer than 30mm extended swaybar links to increase the open length at which the swaybar will bind.
It's the same story for the upper trailing arms, the PS arm won't bind on the fuel tank until an open length of 740mm, so offset upper trailing arms would never really be necessary.
Best
Mark
Best
Mark
Whitey
