OEM strut and shock lengths for Toyota 4wd vehicles
  • OEM strut and shock lengths for Toyota 4wd vehicles
    Hey everyone,
    Similar to the tables for OEM coil spring rates, I thought it would be a good idea to have a table of OEM strut and shock lengths for Toyota 4wd vehicles.
    The table for 120/Hilux/150/FJ series is below;
    All 120/Hilux/150/FJ series are bottom ring-top pin configuration front and rear, excepting the Hilux rear which is ring-ring.
    The table for Landcruisers and older Toyotas is below;
    76/79 series are pin-pin front and ring-ring rear. 80 series are pin-pin front and bottom ring-top pin rear. 100/200 series are bottom ring-top pin both front and rear.
    I’ve added the weights as an identifying feature and also in case anyone is interested in the unsprung masses.
    Many thanks to John at Zordos Suspension for providing struts and shocks for measurements!
    If anyone has some 76 or 80 series OEM shocks for measurement please let me know.
    This is a work in progress, so I’ll update the table every time I get some new data.
    Best
    Mark
    Whitey
    Shockie Maker of the Month Award
    Good day
    I cannot access the dropbox; can you please advise?
    [email protected]
