Std toyota rear shock length
  • Std toyota rear shock length
    Can someone with a standard rear shock laying around please do me a favour and measure it for me.
    I need the length at full compression and at full extension, from the centre of the bottom eye to the base of the stud at the top.
    Thanks in advance,
    Mick
    Re: Std toyota rear shock length
    Thanks in advance,
    Mick
    Mick,
    Full extension is 575mm from centre of bottom eye to base of top stud. Also it's 600mm from centre of bottom eye to the top of the bottom bush with bush plates on.
    Crammy
    2008 GXL M6 D4D, Silver
    Build Up---> [url]http://www.pradopoint.com/viewtopic.php?t=2315[/url]
    [b]{[/b]ATS Ridepro/Bilstein Lift[b]}[/b] [b]{[/b]Dual Batteries with RanOx Battery Booster[b]}[/b] [b]{[/b]600w Projecta 240v Inverter[b]}[/b] [b]{[/b]Dunlop AT3's / MT MTZ's on Speedy Grande Rims[b]}[/b] [b]{[/b]ARB Deluxe Winch Bar[b]}[/b] [b]{[/b]IPF900XS Spotties - Converted to 50w 4300k HID[b]}[/b] [b]{[/b]35w H4-3 4300k HID Hi-Lo Conversion[b]}[/b] [b]{[/b]ARB Underbonnet Compressor[b]}[/b] [b]{[/b]GME TX3440[b]}[/b] [b]{[/b]T-Max 10,000lb winch[b]}[/b] [b]{[/b]Safari Snorkel[b]}[/b] [b]{[/b]Milford Cargo Barrier[b]}[/b] [b]{[/b]Rhino HD Roofies & AT1410 Roof Tray[b]}[/b] [b]{[/b]60L Waeco[b]}[/b]
    [img]http://www.gifs.net/Animation11/Transportation/Cars/4_wheel_drive.gif[/img]
      Thanks Crammy,
      Any idea of the compressed length?
      Mick
        Not at this stage mate. If I get a chance tomorrow I'll see if I can compress one down.
          Why do you need to know ? You thinking of putting some longer ones on ? The Lovels 64612489 100 series cruiser fit and are 620mm long , The Blue max / Gabriel / Iron man -120 series shocks are 618mm long . They all give you more down travel than the standard shocks .The standard shock is 575mm long and 360mm closed
            No, mines already modifed enough..
            Just putting some 80 series shocks on a late model Surf and thought I'd put a bit of a data base together on various Toyota springs and shocks that are interchangable.
            Thanks for the measurements.
            Mick
              Mick,
              Compressed, 355mm and 380mm as per my above post.
              Crammy
                Thanks guys
                Mick
