suspension noise question
  • suspension noise question
    hi,
    just pout a dobinson 40mm kit in the car and the fraont sqeaks a little. the car still has the swaybars in. i am not sure if there is something that i hav don wrong or if the new lift may have altered some of the bushes which may need greasing. Any thoughts would be appreciated before i remove the front struts again
    than ks alan
    Re: suspension noise question
    Worth trying this one before you take the struts out ..........
    Jack the front up and loosen the bottom shockie bolts.
    lower the vehicle back to the ground and tighten the bolts back up again.
    Take it for a test drive.
    Chippy
