Grande Air bags
    garystockton
    Lurker
  • garystockton
    replied
    Re: Grande Air bags
    I'm pretty sure that the rears will be ok, but they certainly won't fit on the front. My Cooper 265/70x17s rubbed on the front and rear guards and lower wishbone, especially under strut compression on full turn lock, until I put in 30mm spacers. Those can probably come off now I reckon. No more rubbing.
    Leave a comment:
  • longdog
    replied
    Grande Air bags
    Is there a problem with fitting 285/70 R17 tyres on the standard Grande rear? I would have thought only the front would have a problem.
    Leave a comment:
  • garystockton
    Lurker
  • garystockton
    replied
    Re: Grande Air bags
    Just finished having my ToughDog / Airbagman suspension kit fitted to my 120 LC5 (Grande equivalent), and am very happy - ride is way better than OEM, the lift is not too hectic, and clearance is better - altogether a class product I think. The kit has everything you need to do the job. Plenty of room now to fit the Cooper 285/70x17 STTs that are on order!
    Time will tell, but I suspect I'll be very happy - roll on Morocco and the Spanish Pyrenees in 2011
    Gary
    Leave a comment:
  • Auto-Craft
    Inactive
  • Auto-Craft
    replied
    Re: Grande Air bags
    I cant say longer bags would be a fix for anything useful, unless using shocks longer than the aftermarket ones currently used, because the standard bags just work, and retaining the mounting pin fixes the blowout problem some have.
    820mm height with standard shocks would be right on the limit for droop of the rear shock as well, so to run this height self levelling doesnt really make sense to me.
    Leave a comment:
  • Mick01
    replied
    Re: Grande Air bags
    No auto levelling and ride height adjustment works exactly the same as the factory set up , regarding price you will need to request pricicng from the Airbag Man as I did a deal with him as I provided input in the eginneering process.
    Leave a comment:
  • Guest
    Guest
  • Guest
    Guest replied
    Re: Grande Air bags
    Originally posted by Team Piggy
    So the ride height adjustment is now lost? and Auto levelling settings?
    Costs?
    Leave a comment:
  • Guest
    Guest
  • Guest
    Guest replied
    Re: Grande Air bags
    Leave a comment:
  • OldGreyGuy
  • OldGreyGuy
    replied
    Re: Grande Air bags
    Originally posted by Mick01
    regaring pictures it pretty much loos like the photos of the Air bag Man one already shown on this site.
    Is this the link to the thread with the Airbagman photos?
    I can't tell right now as that link is blocked by the old work firewall/content filter. I guess I'll just have to check it out tonight.
    Leave a comment:
  • Mick01
    replied
    Re: Grande Air bags
    I am aware of Grandes being lifted by adjusting the levels sensors or spacer blocks being installed and fitting limiting straps to limit the travel on them,
    The conversion I have done, instals a longer bag with no need for spacers or limiting straps, and the bag has enough length to work woth a long travel shock and still be retained on the spring seats at maximum length
    Leave a comment:
  • Guest
    Guest
  • Guest
    Guest replied
    Re: Grande Air bags
    Some of the members here have had a lifted Grande without the need of changing the airbags for a number of years now.
    Mine is one of them.
    What retainers has he used?
    Pictures???
    Leave a comment:
  • Mick01
    started a topic Grande Air bags
    Grande Air bags
    To all,
    it has now been done a 2 inch lifted Grande Air Bag is now availalbe from the AirBag Man is QLD, I have installed the first set last weekend and It all fits great and the height control sytem still works fine. Standard height is now 820mm from bottom of rim to guard.
    Thanks to Brett Cutis of the Airbag man to help me with the convewrision a job well done
