Started out with a slight rear wheel bearing noise, took it to toyota they confirmed wheel bearing and replaced both rear wheel bearings.
All good for about 1 week then the rear right went, took it back and they said it may have been faulty bearing so they replaced it.
2 weeks later and its making the noise again rear left, they have said that it may have been damaged during installation to drop it back in and they'll replace. dropped in they had for 1 week and called to say that they do not have the correct tool to remove/install the bearings. This is when my jaw dropped. I paid $1400 for parts and labour for both rears to be replaced originally... who knows what they did. and if they are honest does anyone know what could cause these to keep failing... talking like 500-1000kms. The vehicle has 150,000 on the clock.
they said they took off all the axles, CV's etc and checked they were all square and balanced which all checked ok..could this noise be something else that is being disturbed then disappears for about 1week and returns? The bearings from what i'm told are worn so is definately them.
I have no clue where to go from here.. at least they are doing the work under warranty but out of the last 5 weeks they've had my car 3 weeks.
Any ideas
Any ideas
