Where to buy Ride Pro in SA??
  • Where to buy Ride Pro in SA??
    in south aust can you get them--andy
    2007 Grey Gxl, ARB bar ,Lightforce xgts HID100watt ,RFDS radio,Cooper St
    Icon radio,duel batterys, engel 40litre Raw 50mm lift
    Re: ride pro where
    Altrac 4x4 on South Rd. (Mile End)
    Mick
      Re: ride pro where
      Total Traction Tyres, 80 OSullivans Rd Lonsdale as well,
      Bev
      Bevan
      Former - 04 TD GXL, Now 2010 LC200 TD
      Tassie
        Re: ride pro where
        G'day Andy
        Altrac have them... I have ordered a set (about $165 each).. they have been on back order for 2 months.. They should have landed at Ateco today and should arrive at Altrac by friday.. Apprently they ran out of stock and then decided to change the design so thats why they have not been available for a while.. They are still 3 stage height adjustable but apparently on par with the bilstein struts now.
        Total traction have them and Darren will supply and fit for around $550 including a wheel alignment
        Jarrad
          Re: ride pro where
          Originally posted by crowey
          G'day Andy
          Jarrad
          They have been on back order, but the deign has been available for some time now, and the struts are from a new manufacturer, on par with a Bilstein, well, I guess a mew Mitsubishi Challenger owner might think his car is on par with a PRado too :mrgreen:
          The height adjustment is also a strut out, compress spring, re install to change it.
          I may have had something to do with the set up, and testing of some of the new stuff coming through 8)
          Did someone say remote res coming soon, and cad plated 2.5's with remote res :shock:
            Re: ride pro where
            Got the ridepro's yesterday.. $330.. they are a 4 stage adjustable height strut now, not 3.. I put the clip on 3 (1 from the top) and after a wheel alignment and driving around it has settled at 795mm (was 740mm) :shock: :shock: i only wanted to go up about 30mm. It now sits 10mm lower at the front and the wheel alignment is basically at its max..
            I used my TJM springs not sure what rating they are, but rides great and looks pretty good
              Re: Where to buy Ride Pro in SA??
              Darren.
              I am interested in the new remote cannister units, let us know when they are out.
                Darren
                Having not long ago put your premium Bilstein package in I am not in the market to upgrade, I am however interested in the details.
                Bev
                Bevan
                Tassie
                  Re: ride pro where
                  Did you work out which clip was factory height, to know each one above that would lift it by almost double the distance of the measurement between each groove on the shock ?
                  This is how you should of worked out your 30mm extra height over std.
