Standard Front and Rear height
  • Standard Front and Rear height
    Hello Pradopoint's,
    Does anyone have the standard front and rear heights (before sag, before lift) of a standard 120, petrol?
    I have been using 750mm for the front and 780 for the rear (measured from the lowest lip of the rim). Been using these numbers to work out an estimated height after lift (mainly the rear), but think my starting point is wrong and my numbers are a little low. Not sure if its available on any of the Toyota specs?
    There is a suspension data base on here. I think in the 120 suspension section.
      Did you search and check the suspension data base here? They are all on that.
        Yes, I have found the spring and shock database to be fantastic, but doesn't include vehicle Std heights . I have also seen data collected of heights depending on the setup which I think is what you are referring to.(although I can't find it just at the moment).
        A mate also gave me some info off the NSW RTA site that is apparently used when checking vehicles. It quoted 522 front, 558 rear measured from the centre of the wheel. So adding say 240mm (i.e. measuring from the bottom wheel ridge) give around 762 Front, and 798 Rear.
          I know I'm being pedantic. But last car I got a lift done I ended up 5-10mm to spare getting it in the garage. Just want to do my research.
            So go adjustable front shocks, and tell them what you need the rear to sit at maximum. Working off a database wont allow for your car in case it has different size tyres, sagged suspension etc.. Better to work off the actual vehicle I would have thought? My 120 petrol with a 40mm rear 50mm front lift and 70 series tyres got under 2100 easily. I think I squeeze it under 2000
              Garage a little under 2M. Will recheck on the weekend and make a call.
              Thanks for the feedback
