Hi guys, just moved up from my older 90 series to a 2007 120 series prado that is mostly stock standard
I’m based in NZ, use the truck for a heap of hunting, 4x4 access (mainly for hunting) up rivers etc
So the plan is to put a bar and winch on the front
wheels are sorted with 265/70/17 tyres on 0 offset steel rims
Ecu has been chipped for a bit of extra power
3” exhaust right through
So the question is what suspension do I go for?
I’m looking at the EFS suspension kit
Or bliesten/dobinson/or king springs
I’ve been reading a lot with the suspension database and just finding it a lot of numbers etc
What kits are you guys running?
what shocks and springs can I run safely that have a nice travel/ride?
Really wanting 50mm lift with as much travel as I can.
can I go for the hilux BE5-D563 shock ?
what spring to go with that?
can I go for the B46-1478LT rear shock? What spring?
many other mods that I need to do to keep things safe?
or is it easier to just go with the standard shorter shocks?
thanks in advance!!
thanks in advance!!
