How much extra lift do you get with the Air Suspension compared with the GXL/VX ???????
Grande Suspension Question !
The Grande only has adjustable rear end airbags. From memory its 30mm from the normal ride height to the low setting, and raises 40mm from the normal to high setting. So an overall movement of 70mm between low and high.
As for the actually extra clearance over the other models you will find that on the toyota website, again from memory the Grande has 205mm clearance and the others have 185 or 190mm. Correct me if I'm wrong.!
Update... I just checked the Toyota site myself. They show a ground clearance of 205mm on all the models now. So maybe they've changed the specs on the new 07 models.! I'm sure last time I checked they were as I previously stated. :!: :roll:03 Grande V6 4.0L, ARB Deluxe winch bar, XD 9000 Warn winch, Pacemaker Headers, Colour Coded Safari Snorkel, K&N Airfilter, Slotted RDA rotors, 55W HID Hella Rallye 4000 spotlights, Dual batt, TJM comp, TJM underbelly bashplate and custom stainless front bashplates, Extended diff breathers, Reverse camera (Eclipse), Yokohama AT-S, ICON 2.5 adjustable remote resi coilovers(front) ICON 2.5 piggyback shocks(rear), 2" lift airbags, Icom ic400pro, Engel 40L, Custom drawer system, Stainless recovery points, Kimberley MyCube rooftop camper.
