Lovells Specifications
  • Lovells Specifications
    Thinking about fitting new springs and after trawling through many of the posts on Lovells coils, I was able to obtain the specs from Lovells themselves to assist others in comparing the myriad of coils available. I have also copied the specs provided by 8608 (with acknowledgments) on a different thread for comparison to OME. I hope this is both useful and within guidelines, if not, please feel free to delete.
    LOVELLS 120 SERIES COILS
    Front:
    TFR-118 Medium: 799Lb/in
    TFR -118 Heavy Duty: 984Lb/in
    TFR -118 Extra Heavy Duty: 1125Lb/in :shock: (Maybe for an Abrams tank?)
    Rear:
    TRR-119 Medium: 261LB/in
    TRR-119 Heavy Duty: 321Lb/in
    OME suspension Specs
    OME Front Coils
    PART NO: OME883 (0-50KG) X
    FREE HEIGHT: 375MM
    SPRING RATE: 590lb/in
    PART NO: OME884 (51-100KG) X
    FREE HEIGHT: 390MM
    PART NO: OME885 (101-150KG) X
    FREE HEIGHT: 395MM
    REAR COILS:
    PART NO: OME895 (MEDIUM LOAD) X
    FREE HEIGHT: 390MM
    SPRING RATE: 260lb/in
    PART NO: OME896 (150KG - 400KG)
    FREE HEIGHT: 390MM
    SPRING RATE: 318lb/in
    PART NO: OME897 (CONSTANT 400KG)
    FREE HEIGHT: 390MM
    SPRING RATE: 387lb/in
    2004 GXL V6, 5 Sp Auto
    Re: Lovells Specifications
    That is interesting the OME front springs r the same rating just taller which obviously allows for more sag??
    [b]Rob[/b]
      I have the 883's in the front and not happy with the nominal lift. Wish I had these specs prior to fittment as I would have grabbed the 884's but the installer insisted the spring rate was higher and with just an ARB deluxe bar would be a bit firm.. :?
      Im sitting at around 770 in front with 883 and bar only (D4D auto), is that about right? Any other PP's with this specific set-up sitting higher?
      Micheal.
        With steel bar and diesel, would have definately went 884, i have alloy and petrol so 883 is good for me.
        [b]Rob[/b]
