Grande 120 Suspension Upgrade
  • Originally posted by topic97 View Post
    and the other question - diff drop or not for a 2 inch lift? yay or nay?
    Diff drop is required if the lift is higher than 2" or the open length of the strut is longer than "normal" i.e. if the open length is around >570mm
      Ahh ok then, so not really any need if im just going the standard 2" on say a dobinsons or bilstein/kings kit?
      • Originally posted by Plums View Post
        Cool. We are lifting the front 40mm kit first with Dobinsons gear (anticipate 80mm lift from current position) , and just a 20mm sensor tweak on the back first without changing shocks or bags. Then I can decide if I think I need a rear lift or not. If not I'll just replace rear shocks and probably get replacement Toyota bags. (This will give me the old spare bags/shocks to take to the Simpson for emergency purposes - and therefore removes my worries).
        Does anyone know if the Toyota bags are identical or are there LHS/RHS ones? If they are the same, I'll just take one bag and one shock as a spare.
        There is a left and right. They are NOT interchangeable.
          Thanks mate, see you tomorrow morning for the big fit out !
          Thanks again for all your advice and help !
